Hi, I've builded and installed a WinCE6.0 image on my 2440, following this suggestions: http://www.friendlyarm.net/forum/topic/203?lang=en it works fine! ( thanks Clemente for the italian guideline!!) Then I tried to develop and deploy an application written in C#, and here I've found some problems. 1) About the deploy, the problem could be that the CE image builded has not activeSync installed, but I'm not sure. I've tried to create a new image using the platform buider, but I always get some little errors. Could it be that I'm using VS2005 Standard (licensed) instead of the professional? 2) Also when I try to execute directly in the 2440, using a SD card, I cannot launch any application, even if I put the dll in the same folder. Could it be (as before) that the image has not Framework2.0 inside? Any suggestions would be appreciated!! Thanks, Claudio
Developing end deploying .NET application on CE6.0
Hello. 1) Don't know. 2) If you want to run on WinCE applications wich was created with .NET Framework you MUST install .NET Framework runtime on device, you can find cab files via google to install directly from SD card, without ActyveSync. Or you can download installer from microsoft.com, unpack it and find package you need.
Another approach: CE seems to work only with shortcuts. The environment variables are empty. Even by itself, so applications can not be readily mapped. Perhaps it is indeed that.
Thanks everybody, I have installed activeSync on my developement machine,and on the device there should be the CF, but I was developing with vs2005...it should be the problem! In any case I'm installing VS2008 complete,then I'll try. But the most intersting feature is the fact that CE works only by shortcuts. I completely ignored it. I'll try as soon as possible. Thanks again, Claudio
