Hi @all, i'm a beginner with the mini2440 board (actually i got a sky2440, but its almoste the same.) the board + 4.3" LCD works great with the delivered uboot/kernel/image with qtopia 2.2 now i cross-compile QT embedded 4.7.3 without erros and copied the libs and bins to the mini2440. i changed the startupscript /etc/init.d/rcS and the script at /bin/qtopia to start the "mainwindow" from QT demos instead of the "qwe" from qtopia. after the TS_calib window (which works perfect) my display doenst show everything (the ts_calib image is still on the display) but it should start the "mainwindow" when i telnet to the mini2440 and run the "mainwindow" manually theres no error, just a echo about the screen size (480x272). but also no image on the display. is there a way to show the shell / errors on the LCD? so that i could see if theres a error and run commands when i have a usb-keyboard attached?
QT 4.7.3 / no Image / Console on LCD?
Hi antifish, Could you please tell me about the steps to compile the Qt, or can you send me the compiled qt?
Hi Jose, i'm still struggling with diffrent toolchains, rootfs, bootloader etc etc :) i think it really depends which toolchain you use to try compile the QT4.7.3 but what works is this way: - install buildroot with this tutorial http://pauljones.id.au/blog/2010/07/using-buildroot-on-a-mini2440/ - after the "make mini2440_defconfig" start the menuconfig, go to Toolchain options, select C++ support - go to Target Options, Graphic Libraries, select QT in QT options, select the accept free license and don't forget to add TSLIB in the Mouse options - exit menuconfig, save changes MAKE :) (need hours...) after that you have a uImage (Kernel for U-Boot), rootfs (as tar and as jffs2)with the qt libs included and a working toolchain in ../buildroot/output/host/usr/bin as i dont use u-boot (and the kernel builded by buildroot has no nand support) i only use the generated toolchain and the QT4.7.3 libs in ../buildroot/output/build/qt...
