Hi everyone.. I installed DNW and then connected my mini2440 to my pc. Then i followed the instructions in the usb download manual(please see the attachment) upto downloading the "yaffs root image via usb". Then the manual says i should reboot my board with the boot mode switch at the NAND position. But after doing this my board is not booting... Where have i gone wrong... or do i need to do anything more??? Please help Thanks in advance Chinmay
2440 not booting
Adding to my previous post.... The first command in the manual is to format NAND flash... has this erased everything.... do i need to put some things back on to the board???? please help Thanks Chinmay
If you followed the instructions and everything is transmitted successfully (the root image takes some time) then linux/qtopia should boot. You will also see informations in the DNW window, if you have the serial cable connected and boot from NAND. Tom
Thanks Tom. I followed the instructions in the manual and loaded everything. I connected the serial cable and booted the board with NAND flash. Here is what i see on the DNW screen s3c2440-nand s3c2440-nand: Tacls=3, 29ns Twrph0=7 69ns, Twrph1=3 29ns NAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung NAND 128MiB 3,3V 8-bit) Scanning device for bad blocks Bad eraseblock 21 at 0x0000002a0000 .. .. Bad eraseblock 791 at 0x0000062e0000 Creating 4 MTD partitions on "NAND 128MiB 3,3V 8-bit": 0x000000000000-0x000000060000 : "supervivi" 0x000000060000-0x000000260000 : "Kernel" 0x000000260000-0x000040260000 : "root" mtd: partition "root" extends beyond the end of device "NAND 128MiB 3,3V 8-bit" -- size truncated to 0x7da0000 0x000000000000-0x000040000000 : "nand" mtd: partition "nand" extends beyond the end of device "NAND 128MiB 3,3V 8-bit" -- size truncated to 0x8000000 ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver s3c2410-ohci s3c2410-ohci: S3C24XX OHCI s3c2410-ohci s3c2410-ohci: new USB bus registered, assigned bus number 1 s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000 usb usb1: New USB device found, idVendor=1d6b, idProduct=0001 usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 usb usb1: Product: S3C24XX OHCI usb usb1: Manufacturer: Linux 2.6.29.4-FriendlyARM ohci_hcd usb usb1: SerialNumber: s3c24xx usb usb1: configuration #1 chosen from 1 choice hub 1-0:1.0: USB hub found hub 1-0:1.0: 2 ports detected Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. usbcore: registered new interface driver usbserial usbserial: USB Serial Driver core USB Serial support registered for pl2303 usbcore: registered new interface driver pl2303 pl2303: Prolific PL2303 USB to serial adaptor driver mice: PS/2 mouse device common for all mice s3c2410 TouchScreen successfully loaded input: s3c2410 TouchScreen as /devices/virtual/input/input0 S3C24XX RTC, (c) 2004,2006 Simtec Electronics s3c2410-rtc s3c2410-rtc: rtc disabled, re-enabling s3c2410-rtc s3c2410-rtc: rtc core: registered s3c as rtc0 i2c /dev entries driver s3c2440-i2c s3c2440-i2c: slave address 0x10 s3c2440-i2c s3c2440-i2c: bus frequency set to 98 KHz s3c2440-i2c s3c2440-i2c: i2c-0: S3C I2C adapter S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics s3c2410-wdt s3c2410-wdt: watchdog inactive, reset disabled, irq enabled mapped channel 0 to 0 s3c2440-sdi s3c2440-sdi: powered down. s3c2440-sdi s3c2440-sdi: initialisation done. s3c2440-sdi s3c2440-sdi: running at 0kHz (requested: 0kHz). s3c2440-sdi s3c2440-sdi: running at 198kHz (requested: 197kHz). s3c2440-sdi s3c2440-sdi: running at 198kHz (requested: 197kHz). s3c2440-sdi s3c2440-sdi: running at 198kHz (requested: 197kHz). s3c2440-sdi s3c2440-sdi: powered down. usbcore: registered new interface driver usbhid usbhid: v2.6:USB HID core driver Advanced Linux Sound Architecture Driver Version 1.0.18a. No device for DAI UDA134X No device for DAI s3c24xx-i2s S3C24XX_UDA134X SoC Audio driver UDA134X SoC Audio Codec asoc: UDA134X <-> s3c24xx-i2s mapping ok ALSA device list: #0: S3C24XX_UDA134X (UDA134X) TCP cubic registered RPC: Registered udp transport module. RPC: Registered tcp transport module. lib80211: common routines for IEEE802.11 drivers s3c2410-rtc s3c2410-rtc: setting system clock to 2161-10-02 14:02:03 UTC (1756193627) yaffs: dev is 32505858 name is "mtdblock2" yaffs: passed flags "" yaffs: Attempting MTD mount on 31.2, "mtdblock2" yaffs: auto selecting yaffs2 block 3 is bad .. .. block 773 is bad yaffs_read_super: isCheckpointed 0 VFS: Mounted root (yaffs filesystem) on device 31:2. Freeing init memory: 128K Warning: unable to open an initial console. Failed to execute /linuxrc. Attempting defaults... Kernel panic - not syncing: No init found. Try passing init= option to kernel. Where am i going wrong??? Please help Thanks Chinmay. PS. I have attached the file containing the complete details of the problem from the DNW screen
Do you have connected a display to the board and also what power supply do you use? You need a 5V power supply with at least 1A. Regards, Andreas PS: Please dont upload files to the forum which are already in the download section. (download.pdf)
Problem solved!!!!! Thank you all The packaging of my friendly arm said that it has a 64M Flash Actually it has a 128M Flash :) So i put the necessary files for the 128M Flash And it worked.. Thanx again for your time everyone..\ Now All is Well!! Chinmay
Neither Linux nor WinCE will boot stand alone with my board. The only way to get the Mini2440 booting is using DNW's Boot command. I have tried both 128 M and 64 M flash versions of SuperVivi. Any ideas? Regards, Peter
