Hey guys, I compiled everything into my kernel for GPIO. Now i'm soldering a simple red LED to one of the GPIO Pins ión my mini2440. Including resistor. But the sysfs won't accept my commands. When I do echo 1 > /sys/class/gpio/gpio32/value the onboard buzzer is making noise, so i think the basic GPIO sysfs is working. # cd /sys/class/gpio/ # ls export gpiochip128 gpiochip192 gpiochip256 gpiochip64 unexport gpiochip0 gpiochip160 gpiochip224 gpiochip32 gpiochip96 # echo 164 > export # cd gpio164/ # ls active_low edge subsystem value direction power uevent # cat value 0 # cat direction in # echo out > direction # cat direction out # cat value 0 # echo 1 > value # cat value 0 I'm using Pin 3 for Ground and Pin 13 for the LED. Refering to the manual PIN 13 is EINT4 which is GPF4, so it must be 5*32 + 4 = 164. Any ideas why it isn't working?
GPIO with simple LED not working
OSELAS.BSP-Pengutronix-Mini2440-Quickstart.pdf at http://www.oselas.org/oselas/bsp/pengutronix/mini2440_bsp_en.html section 4.5 has a good section on using LEDs
Hi Gr3yh0und, I just did the same as you, and here the pin 13 at connector CON4 changes from 0 V to 3.3 V and back to 0 V if I write 0, 1, 0 to the "value" entry. Are you sure you connected your led to the correct pin 13? Pin 1 of CON4 is near the SD card connector, the inner row of CON4.
