Hello
Is it possible to use "1x miniUSB Slave/OTG 2.0" as USB 2.0 Host ?
I saw on other hardware OTG kernel options to force it to work in host
mode. I guest I need at least OTG and EHCI drivers in linux kernel, but
EHCI seems to be disabled ("USB_ARCH_HAS_EHCI [=n]").
Mini6410 - usb host 2.0
I am looking for same subject. I agree about need of ehci driver. My idea looking last linux release is that this item is "working in process". Would be great that somebody help us. I am using mini6410 and really i didn't find anything about host 2.0 in otg port. Which libusb are you using? 0.1.x or 1.0.x ?
I have both .so files, but I use usb only for kernel side devices. Probably even if OTG would work as Host - it will be USB1.1 only, because drivers don't use EHCI at all.
I try to connect OTG as host. I made some tentative: - force OTGID to GND doesn't work - use one external hub with self power supply doesn't work The other host 1.1 work with no problem. If I let PC connected at bootstrap I see some message that seems like try to connect some devices unsuccessful on port 2. (this with OTGID not connected to GND). I am using on my application libusb 0.1.12 that work with no problem on the other host side. Some suggestion?
Hi there, Got the same problem ! I need to plug a wifi n 300Mbps usb dongle so usb 2.0 is the only way to achieve that. I did the same tweaks as enore grattoni with no success. How can I switch the mini USB OTG from slave to host ? Thank you in advance
