Hi people. Iīm having the following problem: Iīve downloaded DNW because I need to access the boot options screen to backup my NAND flash and install Android image. My USB and serial cables are plugged in and when I open DNW it shows that USB is OK and COM1 port is connected at [COM1,115200bps]. Apparently is all perfect, as described at "Downloader Instructions" manual, but the bootloader menu options donīt appear. My mini2440 boot mode switch is set to NOR flash. Iīve tried to access from HiperTerminal and I get the same result. I have no idea about how to solution this problem. Is it possible that bootloader was erased? Any help is welcome. Thanks everyone.
BIOS menu does not load
Does the board boot linux/wince? Is your COM port at COM1 and have you tried another serial cable? Do you also use a USB-to-RS232 converter?
To access the menu, you have to press reset after a successful connection. Or just turn the board off and on again.
Hi. Thanks for replying. dafrev: I donīt have a JTAG adapter. Roger: Yes, now the board boots Qtopia linux and I donīt have another serial cable to test. The cable is new and I donīt think itīs broken. About the USB-to-RS232 adapter, I donīt have it. Is it necessary? Iīm using a serial cable and a direct USB cable (a usb printer cable). Killerwatt: I press reset button and power on/off and still nothing happens. Iīm still trying more things but itīs still the same. Thanks everyone for helping me.
If the system boots then you should have an output on the serial port. The serial cable must be straight, not crossed. > About the USB-to-RS232 adapter, I donīt have it. Is it necessary? Iīm > using a serial cable and a direct USB cable (a usb printer cable). No its not necessary - some USB-Adapters make problems. Cheers Roger
Roger, You were right. My cable was crossed and I replaced by a straight one and everything worked fine. Thanks for the help.
