Booting into default image that came with mini2440, and firing up the audio recording application, I recorded some voice sample, talking into the inbuilt mic from about 6 inches away (so I consider it pretty close), but when I play it back at max. volume, I can barely hear. I fed the headphone output to an amp, and only then I could hear reasonably, but still the levels were fairly low. So wondering, if someone else faced this issue. Is there a way to increase a the mic gain ? Will it help to replace the default mic with a high pick-up / high sensitivity mic ?
mini2440 audio recording, is it mic issue ?
I've mic issue with full duplex support and audio level and i cant solve it too, There is a member suggest me that to replace adc line by new mic(with amp circus) and re-write driver for that. How do you think? Right now i dont have time to do that.
