There is a problem on my MINI2440 kit, the [f] Format the nand flash option was chosen. This erased the Bootloader parameters table, and the USB port is no longer being activated. At the beginning it appeared to be a Superviviīs problem, however Iīve flashed several versions using JTAG, and the problem persists. Iīve activated the port when it stopped working some months ago, because I found the procedure on the web, this is how I know itīs possible. I think itīs just a matter of adding the USB port to the bootloader parameters table.
