Seems that 2G AND flash is not supported with u-boot image coming on CD
(see output below). Is there any newer version available?
Thanks,
Damjan
U-Boot 1.1.6 (Dec 31 2010 - 14:36:43) for FriendlyARM MINI6410
CPU: S3C6410@532MHz
Fclk = 532MHz, Hclk = 133MHz, Pclk = 66MHz, Serial = CLKUART (SYNC
Mode)
Board: MINI6410
DRAM: 256 MB
Flash: 0 kB
NAND: NAND device: Manufacturer ID: 0xec, Chip ID: 0xd5 (Samsung NAND
2GiB 3,3V 8-bit)
NAND bus width 8 instead 16 bit
No NAND device found!!!
0 MB
tiny6410 2GB NAND support
Hi the old u-boot can only read and boot Linux now. but the new u-boot is coming soon. I will post it this week. and the new Superboot is released alreay, here is the Chinese link: http://www.arm9home.net/read.php?tid-12717.html its new feature: - support LCD mode - add two key words define: * LCD-Mode = yes * LCD-Type=N43 ; or A70, N35, T35, L80...etc - support nand-boot Linux/wince/Android, so you can replace all kinds of u-boot. - detect the RAM size, Flash type/size automatically - select OS and install via K1, K2, K7, K8, easy to use. please wait and try. regards mindee
I have the same problem after recompiling kernel 2.6.28 and using
rootfs_qt4 (recompiled) :
U-Boot 1.1.6 (Oct 6 2011 - 13:52:26) for FriendlyARM MINI6410
CPU: S3C6410@532MHz
Mode
Board: MINI6410
DRAM: 256 MB
Flash: 0 kB
NAND: 2048 MB
In: serial
Out: serial
Err: serial
It works if I use the images in the Tiny CD-Rom.
Any idea ?
