Hello Please im trying to boot the tiny6410 from sdcard channel0, on boot i get those errors: s3c-fimc: controller 0 registered successfully s3c-fimc: controller 1 registered successfully FIMC Driver, 2010 ported by FriendlyARM http://www.arm9.net ov965x: probe parent clock for camera: 266.000 MHz, divisor: 11 [CAM]RESET CAM. S3C6400 MFC Driver, (c) 2007 Samsung Electronics, 2010 ported by FriendlyARM http://www.arm9.net S3C6400 MFC Driver init OK. S3C PostProcessor Driver v3.12, (c) 2009 Samsung Electronics S3C6410 TV encoder Driver, (c) 2008 Samsung Electronics S3C6410 TV encoder Driver init OK. S3C6410 TV scaler Driver, (c) 2008 Samsung Electronics S3C6410 TV scaler Driver init OK. S3C Rotator Driver, (c) 2008 Samsung Electronics s3c_rotator_probe called s3c_rotator_probe success S3C JPEG Driver, (c) 2007 Samsung Electronics s3c_g2d_probe called s3c_g2d_probe Success S3C G2D Init : Done S3C G3D Driver, (c) 2007-2009 Samsung Electronics s3c_g3d version : 0x1050000 S3C G3D Init : Done usbcore: registered new interface driver uvcvideo USB Video Class driver (v1.0.0) S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics s3c2410-wdt s3c2410-wdt: watchdog inactive, reset disabled, irq enabled sdhci: Secure Digital Host Controller Interface driver sdhci: Copyright(c) Pierre Ossman s3c-sdhci s3c-sdhci.0: clock source 0: hsmmc (133000000 Hz) s3c-sdhci s3c-sdhci.0: clock source 1: hsmmc (133000000 Hz) s3c-sdhci s3c-sdhci.0: clock source 2: mmc_bus (24000000 Hz) mmc0: SDHCI controller on samsung-hsmmc [s3c-sdhci.0] using ADMA s3c-sdhci s3c-sdhci.1: clock source 0: hsmmc (133000000 Hz) s3c-sdhci s3c-sdhci.1: clock source 1: hsmmc (133000000 Hz) s3c-sdhci s3c-sdhci.1: clock source 2: mmc_bus (24000000 Hz) mmc1: SDHCI controller on samsung-hsmmc [s3c-sdhci.1] using ADMA usbcore: registered new interface driver usbhid usbhid: USB HID core driver TCP cubic registered NET: Registered protocol family 17 can: controller area network core (rev 20090105 abi 8) NET: Registered protocol family 29 lib80211: common routines for IEEE802.11 drivers VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5 s3c-rtc s3c64xx-rtc: setting system clock to 2000-01-03 10:44:06 UTC (946896246) Freeing init memory: 1408K mount: mounting /dev/mmcblk0p2 on /r failed: No such file or directory /init: line 103: can't open /r/dev/console: no such file Kernel panic - not syncing: Attempted to kill init! [<c0177c44>] (unwind_backtrace+0x0/0xe4) from [<c04f4ba0>] (panic+0x58/0x174) [<c04f4ba0>] (panic+0x58/0x174) from [<c018a5b0>] (do_exit+0x68/0x5e4) [<c018a5b0>] (do_exit+0x68/0x5e4) from [<c018adf0>] (do_group_exit+0x90/0xc4) [<c018adf0>] (do_group_exit+0x90/0xc4) from [<c018ae34>] (sys_exit_group+0x10/0x18) [<c018ae34>] (sys_exit_group+0x10/0x18) from [<c01725e0>] (ret_fast_syscall+0x0/0x30) my parameters are: setenv bootargs 'noinitrd rootwait root=/dev/mmcblk0p2 rw rootfstype=ext3 ip=192.168.0.1 console=ttySAC0 init=/sbin/init' setenv bootcmd nand read 0xc0008000 0x100000 0x400000\;bootm 0xc0008000 kernel is 2.6.38 provided by firendlyarm is /dev/mmcblk0p2 the correct device name for mmc channel 0 partition 2 on the 38 kernel?
