Hello, Recently i bought Mini35 board that runs Linux 2.6.29.4 kernel + Qtopia. As I am not a authentic Linux developer so, i need some advise,regarding how to go about making mini2440 a single application device. I dont mind the current kernel, but i need to run a single application(Qt based). So i need to know how to remove the Qtopia application framework that runs as defult from the file system. Also i have one problem with ping/netstat. After connecting the network cable, i logged in using root. Every thing seems to be fine. But I could not ping my own computer(vista 64) from mini.
Single Application Device
I would have thought if you want to run a Qt based application then you would want to leave Qtopia installed. But, then again I am a beginner. You are pinging 192.168.1.230? No problems here with XP. For the Linux box I had to go in and put the MAC address in. Good luck.
Thank for reply. Mini2440 connected to my laptop using cross-cable could not ping 192.168.1.1(IP Address of laptop). But when i connected mini to router using straight cable, it could ping my laptop!!! But in both the cases my laptop could ping to mini. Qtopia Issue: I know Qtopia is a application development framework using Qt. I will be developing Qt application as a standalone application(NOT a Qtopia application or service). Hence I need to remove the unnecessary stuffs from root file system.
Hi sujeet_nayak, To use your board as a single application device you don't need Qtopia. You can easily build your own rootfs with QT support using buildroot (http://buildroot.uclibc.org/).
