Dear friends,
I have made a lot of modifications on the linux kernel and user partition
on my mini2440, and now it's stable.
I want to keep a copy of the full NAND and use it as a baseline for
production and I think the best is to do a NAND backup and then restore it
to multiple devices.
When I try it I get the following:
[v] Download vivi
[k] Download linux kernel
[y] Download root_yaffs image
[a] Absolute User Application
[n] Download Nboot for WinCE
[l] Download WinCE boot-logo
[w] Download WinCE NK.bin
[d] Download & Run
[z] Download zImage into RAM
[g] Boot linux from RAM
[f] Format the nand flash
[b] Boot the system
[s] Set the boot parameters
[q] Goto shell of vivi
[i] Version: 0945-2K
Enter your selection: u
Backup Information:
Start Addr : 0x0
End Addr : 0x10000000
bBackupOOB : 1
bCheckBad : 1
dwBackupTotalLen : 0x10800000
dwReservedBlks : 28
dwEPInPktSize : 32
Use dnw.exe to receive backup.
supervivi is expecting me to connect with dnw from windows, but I am
working with Ubuntu 10.04 desktop LTE.
How can I upload the image to the host?
How can I download it ti the mini2440 again?
NOTE: I am connected to mini2440 by two means:
1) USB-to-RS232, using the command: cu -l /dev/ttyUSB0 -s 115200
2) USB host on PC to USB device on mini2440 (not in use)
Thank you in advance!
Ricard.
NAND backup and restore from linux (mini2440)
Hello Ricard Bou. I did backup and restore from NAND memory of mini2440 board by using dnw and Hyper Terminal in windowXP (not ubuntu as you mentioned, I also need windowXP to install winCE, linux and android for mini2440). If possible, have a look here to know how to backup and restore mini2440 (in windowXP) http://mini2440vietnam.blogspot.com/2011/01/back-up-and-restore-mini2440... Good luck ^^
