hi everybody ,
I have mini6410 and I want to use analog inputs , but I am new at this
topic and I need help. I wrote some code and compile with arm-linux-gcc
and upload mini6410 and try this code but I have segmentation fault in run
time.
Can you help me ? what is the problems and solutions ?
best regards.
// A/D Converter
#define ADCCON (*( unsigned long *) 0x7E00B000)
#define ADCTSC (*( unsigned long *) 0x7E00B004)
#define ADCDLY (*( unsigned long *) 0x7E00B008)
#define ADCDAT0 (*( unsigned long *) 0x7E00B00C)
#define ADCDAT1 (*( unsigned long *) 0x7E00B010)
#define ADCUPDN (*( unsigned long *) 0x7E00B014)
void initADC()
ADCCON = (1<<16); //select 12 bit /* !!! segmentation fault */
ADCCON = (1<<14); //A/D converter prescaler enable
ADCCON = (0<<5); //chanel select [5:3] 001 is AIN1
ADCCON = (0<<4);
ADCCON = (1<<3);
ADCCON = (0<<2); //Standby mode select = normal mode
ADCCON = (1<<1) //A/D conversion start by read
ADC -mini6410 - segmentation fault
I can only talk from my 8bit experience and even that could be incorrect. First, I would have thought that something like #define ADCTSC would already be done for you. Perhaps, you are trying to do it the hard way for some experience. Are you sure you have the locations? Also, I think they are normally done like your 2nd post, i.e. volatile. Secondly, a statement like: ADCCON = (1<<16) may not be doing what you expect. I would have done ADCCON |= (1<<16) or even better still there is probably an ADC register name like, ADCSR and some bit names for the various functions within that register like ADCON that would allow you to do: ADCSR |= (1 << ADCON); i.e turn ADC on The |= says ONLY change (set) that particular bit and don't mess with any of the others. ADCCON = (1<<16); could be messing with other bits in that register. Clearing bits is done like this: ADCSR &= ~(1 << ADCON); i.e. turn ADC off.
