Hi everyone! My name is Luan. I bought a new FriendlyARM and i try to port Linux on it. But i had a problem when the tslib calibrating utility appears, i could not touch the screen. I try my LCD on another KIT and it works perfectly. I also try another LCD on my KIT. The problem occured again. What is the problem on my KIT and how to solve it . Thank you so much !
LCD touch screen doesn't work
Well, it will help if you tell us what your "KIT" is and what kernel you ported and which rootfs you are using and how you downloaded it to the board. IE, what bootloader you are using.
Sorry about late davef, I am using all uboot, kernel and rootf from the DVD which i have from FriendlyARM. It worked few times before, but this time it doesn't work :(
Well, taking the images from the DVD and following the DNW downloader guide should give you a working system. Something that could help would be, for you to capture the messages that occur during bootup and look for words like "error" or "unable" or any other negative comments. Post the full message that you get on DNW and maybe someone can help you out.
