Hello, I'm using a Micro2440-evaluation board and hanging on an boot failure in u-Boot bootloader. It says "Starting kernel..." and then it stops. I would expect the next step is "Uncompressing ...". All my created uImages do not work. When I load the corresponding zImage into Supervivi, everything works fine. But I need u-boot because of SD card boot support. I tried different toolchains (buildroot, FriendlyARM, Codesourcery) but nothing has changed. The u-boot version is the one from the download area on this page. So can somebody help me, getting my mini2440 to work? I think it is the same error Dirk describes at the end of thread http://www.friendlyarm.net/forum/topic/2284 . Marius
u-boot hangs on "Starting kernel..."
What u-boot version you're using? Which kernel? Maybe enabling in kernel config DEBUG_LL could help to see what happens. Which board version (mean flash size). marek
Hello marek, the u-boot version is the one from the download area (http://www.friendlyarm.net/dl.php?file=u-boot_20100701.zip). I tried different kernel versions but mainly the one from the git-repository: git://repo.or.cz/linux-2.6/mini2440.git I will compile with DEBUG_LL enabled and report the results. At the moment I think the uImage could be broken, because Supervivi can boot the zImage without any problem. And also U-Boot starts decompressing, when I use "go 0x30008000" on the zImage in memory. But after decompression it also stops working. Marius
Hello, I built the kernel from GIT with DEBUG_LL enabled and the result is the same. Kernel won't boot up. I have attached my uImage and zImage. Maybe someone could test them. The zImage boots fine in Supervivi unless panic because of missing root-fs, but that's normal. I have the 256 meg version and maybe someone could send me some images (u-boot and uImage) to test. Marius
Binary files are most of the time useless for others to test. What should we test with this file? What we need is the exact source tree, your configuration to build this kernel, the toolchain that builds your kernel.
