Hi I have Micro2440 and the Schematic on the DVD that i have received does not specify to which port is the pin numer 8 is connected to.I have attached the schematic . Any help will be much Appreciated.
Micro2440-Con6
For the proper function of this pin is not needed! With a lot of background knowledge, you can abuse them for their own purposes. You will probably have to tap directly and then tweak the code.
