IS THERE ANY ONE WHO KNOW SOMETHINGS ABOUT NANDBOOT(S2(=SWITCH 2)) ? WHERE IS NANDBOOT CONNECTED TO? ON THE SCHEMATICS WROTE THAT IT`S NOT USED.WHAT DOES IT MEAN? IF IT`S NOT USED HOW YOU CAN SWITCH BETWEEN NORFLASH AND NAND FLASH ON EVALUATION BOARD?
NANDBOOT/S2
Do I dare suggest anything here! Well, it is my "opinion" that the box on the schematic with the label S2 on the top and CON5 on the bottom is actually describing that one has two choices here. Either they can mount the switch or they can mount a 5 pin connector, to connect an external switch. Don't connect any wires here until you make it clear what you are trying to do :) Dave
Hello, I have developed a similar board as mini2440 every component is same, but as mini2440 comes with a pre-loaded BIOS, can anyone tell me how do I load BIOS into the MCU ?
Hello Everyone,
Yes JTAG worked thank you , I have one more query the board I am
developing in that I had to implement wireless connectivity like GPS and
Wi-Fi, for this I got a multifunction radio Chip Wilink 7.0 from TI, as I
am using SC32442b Samsung processor, TI did not provide me the drivers for
this processors they gave me for OMAP4 , but I found Linux drivers for
Wilink 7.0 to SC32442 from openlink.org, the problem is I want to run
Windows CE 6.0 on my board , how do I import the drivers or how can I port
the available drivers ? coz writing a new driver by myself is not a good
idea.
Hoping a favorable response.
Regards
Ranjith
Ranjith, You'll have more success starting a new thread, rather than burying your request in an unrelated thread. Also, one post should do the job! Can't help with Windows stuff. Dave
