Hi I have a custom application (its a modified fancybrowser) which runs on a Qt 4.6.2 installation successfully when the QWS_MOUSE_PROTO variable is set to use the mouse event. When I change it to capture the touchscreen event, then the same application gives a seg fault. The tslib files are properly placed on mini2440's nand and environment varibales are set. The ts_calibrate runs fine and so does the ts_test. Just to add, I have put my Qt 4.2 libs over the Qtopia 2.2 installation and modified the env properly. Any Help would be appreciated.
Qt 4.6.2 with tslib - Seg Fault
Do you have the binaries with debug information available? If yes, you could run the 'catchsegv' tool. It will show you the source code line where the segfault happens at runtime. This could give you a hint where the bug is and how to fix it.
