Hi all, I have mini6410 board. Now a days, when try to boot/flash from sd card, I am getting "ID Err". And it stops. I not able to flash the NAND nor boot from SD Card. What does it mean? Or Do I have damaged the board? -Regard Sathishkumar D
"ID Err" What it means?
I see they can move around each time you search :) The one I meant, but probably not what you want http://www.ehow.com/how_5894885_sd-card-id.html Looks more useful http://lists.debian.org/debian-arm/2009/11/msg00032.html Is there more to the error message?
There is nothing more got here except for "IDErr" and then the system stays there, but I ave observed that if the windows system is rebooted, then the boot works fine for the first time and then the problem repeats again. Regards, Nambi
Well, Through Fdisk, I found Disk identifier as 0x931f13be. I also understood the "ID Err" may result because sometimes the sd card's Disk identifier is properly recognised.
