Hi, Just received a Mini with a LCD-W35i on it. My WinCE images (for X35, T35 and N35) doesn't work properly (color bar on one side and desktop appear 90 degrees clockwise) and there's no define in C:\WINCE600\PLATFORM\Mini2440\SRC\INC\option.h for W35 LCD screen. Does anyone figure it out? Regards, Benoit
WinCE driver for LCD-W35i
Hi again, I found a solution. On the DVD that comes with the Mini, there's a option.h file that contains some usefull src. So I added these lines in C:\WINCE600\PLATFORM\Mini2440\SRC\INC\option.h //Around all other LCD define #define LCD_W35 Somewhere in the same page #elif defined(LCD_W35) #define LCD_WIDTH 320 #define LCD_HEIGHT 240 And in C:\WINCE600\PLATFORM\Mini2440\SRC\INC\s3c2440a_lcd.h #elif defined(LCD_W35) #define PROGRESS_BAR_TOP 220 #define PROGRESS_BAR_LEFT 20 #define PROGRESS_BAR_WIDTH 280 #define PROGRESS_BAR_HEIGHT 6 #define LCD_PIXCLOCK 4 #define LCD_RIGHT_MARGIN 0x44 #define LCD_LEFT_MARGIN 0x04 #define LCD_HSYNC_LEN 0x01 #define LCD_UPPER_MARGIN 10 #define LCD_LOWER_MARGIN 4 #define LCD_VSYNC_LEN 1 #define LCD_CON5 ((1<<11) | (1<<8) | (1<<9) | (1<<0) ) Everything is working good now... Regards, Benoit
So is there a new W35 LCD shipped with new mini2440's from now on? Do you have any more specs about it (maker, model..). Does it say W35 on the front plastic bezel?
Hi stereo_m, Yes, it does say W35 on the front and it says LCD-W35i on the PCB where the LCD connect to. I'm still looking for specs, but as far as I can see, it looks to be a LED backlight. For Júlio, I never tried for WinCE 5. Regards, Benoit
hi Everybody I got my Arm 3.5 board(with W3.5 LCD) one week ago, but could not able to create wince image using mini2440 bsp. Always i am getting some error. I have changed few lines also for W3.5 LCD in option.h and s3c2440a.lcd.h, but still getting the same error. here are the error list: Error 1 Catalog Id "StringTable:MS:Deviceemulator:1041" duplicated in files "C:\WINCE600\platform\DEVICEEMULATOR\catalog\1041\deviceemulatorstrings.pbcxml" and "C:\WINCE600\platform\Mini2440\catalog\1041\deviceemulatorstrings.pbcxml" with equivalent version numbers. Ignoring second record (file "C:\WINCE600\platform\Mini2440\catalog\1041\deviceemulatorstrings.pbcxml"). C:\WINCE600\platform\Mini2440\catalog\1041\deviceemulatorstrings.pbcxml 0 Error 2 Catalog Id "StringTable:MS:Deviceemulator:1033" duplicated in files "C:\WINCE600\platform\DEVICEEMULATOR\catalog\1033\deviceemulatorstrings.pbcxml" and "C:\WINCE600\platform\Mini2440\catalog\1033\deviceemulatorstrings.pbcxml" with equivalent version numbers. Ignoring second record (file "C:\WINCE600\platform\Mini2440\catalog\1033\deviceemulatorstrings.pbcxml"). C:\WINCE600\platform\Mini2440\catalog\1033\deviceemulatorstrings.pbcxml 0 Error 3 ENDIF expected. C:\WINCE600\PLATFORM\Mini2440\FILES\platform.bib 236 Error 4 ENDIF expected. C:\WINCE600\PLATFORM\Mini2440\FILES\platform.bib 236 Error 5 ENDIF expected. C:\WINCE600\PLATFORM\Mini2440\FILES\platform.bib 236 Error 6 ENDIF expected. C:\WINCE600\PLATFORM\Mini2440\FILES\platform.bib 236 Error 7 ENDIF expected. C:\WINCE600\PLATFORM\Mini2440\FILES\platform.bib 236 Error 8 ENDIF expected. C:\WINCE600\PLATFORM\Mini2440\FILES\platform.bib 236 Error 9 ENDIF expected. C:\WINCE600\PLATFORM\Mini2440\FILES\platform.bib 236 Error 10 ENDIF expected. C:\WINCE600\PLATFORM\Mini2440\FILES\platform.bib 236 Error 11 ENDIF expected. C:\WINCE600\PLATFORM\Mini2440\FILES\platform.bib 236 Error 12 ENDIF expected. C:\WINCE600\PLATFORM\Mini2440\FILES\platform.bib 236 Error 13 ENDIF expected. C:\WINCE600\PLATFORM\Mini2440\FILES\platform.bib 236 Error 14 ENDIF expected. C:\WINCE600\PLATFORM\Mini2440\FILES\platform.bib 236 Error 15 ENDIF expected. C:\WINCE600\PLATFORM\Mini2440\FILES\platform.bib 236 Error 16 ENDIF expected. C:\WINCE600\PLATFORM\Mini2440\FILES\platform.bib 236 Error 33 error C2065: 'ResponseR7' : undeclared identifier C:\WINCE600\PLATFORM\Mini2440\SRC\DRIVERS\SDHC\SDHCBASE\.\sdiocontrollerbase.cpp 1211 Error 34 error C2051: case expression not constant C:\WINCE600\PLATFORM\Mini2440\SRC\DRIVERS\SDHC\SDHCBASE\.\sdiocontrollerbase.cpp 1211 Error 35 error C2051: case expression not constant C:\WINCE600\PLATFORM\Mini2440\SRC\DRIVERS\SDHC\SDHCBASE\.\sdiocontrollerbase.cpp 1312 Error 36 BLDDEMO: There were errors building OSDesign2 Please Help me to get rid of these error. Regard Ashish Gaurav
hi Ashish Gaurav first try to compile an winCE image, without any modification of any file.. just select your components when you build the image.. like that, you will validate your PB6.0 installation .... you can select the right LCD int the bootloader with terminal on PC.. regards
Hi Phil Thank you for responding. I tried this also but same error is coming. I am sured that my PB6.0 has installed perfectly because i am able to create wince image for default device emulator and its working fine. But i am getting those error every time when i build image for minni2440 bsp(for any of the LCD). Could you please send me the exact mini2440 BSP for winCE6.0 which you have build earlier to my mail id aashish_garv@yahoo.co.in I have also reinstalled everything to another PC, but same error is coming. Any comments and suggestions are welcomed. regards
you can create image for default emulator , it's a good start !.. but that don't say that work with your BSP !... before do any modification in the config files, try with the original BSP and your board, not for an emulator ! sorry i don't work anymore with the 2440, can't provide a good BSP. regards phil
Hello. I have same problem. I have mini2440 this LCD-W35i display and a can't install WINCE 6.0. If I use image for X35, T35 and N35 i get display whith bad orientired (halp display I can't see) :( Please help me I you can!
hi grjgrj have you build new wince image or you are using given wince image on DVD came with mini2440? If you are not creating new image then you can find all necessary file of LCD-W35i in DVD. regard
