Hi Guys, When I want to .configure the Qt 4.6.2, I get "The tslib functionality test failed, you might need to modify the include and library search paths by editing QMAKE_INCDIR and QMAKE_LIBDIR in ......" My compiled tslib is in the /home/tslib/ (bin, etc, include, lib) and qmake.conf has got following remarks ; QMAKE_INCDIR += /home/tslib/include QMAKE_LIBDIR += /home/tslib/lib Looks like everything is okey. I tried "file ts_calibrate" command in /home/tslib/bin , then I got "ELF 32-bit LSB executable, Intel 80386 ....." Is this the problem? I think this is weird, because arm-linux-gcc 4.3.2 is installed on system and I compiled the linux kernel for mini2440 before. (I'm using ubuntu 10.04) I'm doing the steps from http://www.sereno-labs.com/qt-4-6-2-installation-procedure-for-friendlya... and http://mini2440vietnam.blogspot.com/2011/04/upgrade-qt462-in-mini2440.html but I couldn't pass the tslib thing yet. Does anybody help me?
Tslib problem when compiling QT
You have not compiled tslib for the ARM platform. Navigate to where ts_calibrate is located and do: <readelf -A ts_calibrate> Show us your script for compiling tslib.
Hi mocugo It seems your ts_calibrate has problem. I think you should re-compile the tslib. In my computer, "file ts_calibrate" gets this: ts_calibrate: ELF 32-bit LSB executable, ARM, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.14, not stripped
