Dear all, I emplemented the file sharing as per domdom website: http://www.domodom.fr/spip/Sharing-folders-with-Windows-CE-6.html?lang=en and also i enabled the webserver. My device ip: 192.168.1.100 whenenever i put in my browser: http://192.168.1.100 it redirects to the http://192.168.1.100/remoteadmin i did the share configuration, and it is working normally, however i am not able to access the webserver. I even tried to put a new page: called test.htm when i call: http://192.168.1.100/test.htm it redirects to http://192.168.1.100/remoteadmin what can i do to have both working at the same time, Thank you for your support.
File Server and Web Server at the same time
Change the listening port of the file server or the web server. For example change the port of the webserver to 8080 then try to access using http://192.168.1.100:8080/test.htm But you should change the file server port and leave the standart port 80 of the web server.
