Hello guys I have the cable modem internet connectrd to my PC through the DHCP and I want to access the internet on my mini240 board and for that I just connected the internet cable to my mini2440 board and got the following result # eth0: link up, 100Mbps, full-duplex, lpa 0x05C1 It means th emini is detecting the etherenet cable and thereafter I ran this command: # /etc/init.d/networking restart the output is : Reconfiguring network interfaces...There is already a pid file /var/run/dhclient.eth1.pid with pid 25 killed old client process, removed PID file Internet Systems Consortium DHCP Client V3.1.1 Copyright 2004-2008 Internet Systems Consortium. All rights reserved. For info, please visit http://www.isc.org/sw/dhcp/ Listening on LPF/eth1/08:08:11:18:12:27 Sending on LPF/eth1/08:08:11:18:12:27 Sending on Socket/fallback Internet Systems Consortium DHCP Client V3.1.1 Copyright 2004-2008 Internet Systems Consortium. All rights reserved. For info, please visit http://www.isc.org/sw/dhcp/ eth1: link down Listening on LPF/eth1/08:08:11:18:12:27 Sending on LPF/eth1/08:08:11:18:12:27 Sending on Socket/fallback DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 5 eth1: link up, 100Mbps, full-duplex, lpa 0x45E1 DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 12 DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 20 DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 19 DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 5 No DHCPOFFERS received. No working leases in persistent database - sleeping. done. I am not able to get the connection . the /etc/networks/interfaces file is as follows : # Used by ifup(8) and ifdown(8). See the interfaces(5) manpage or # /usr/share/doc/ifupdown/examples for more information. auto lo iface lo inet loopback auto eth1 iface eth1 inet DHCP #auto wlan0 #iface wlan0 inet dhcp # wireless-key 1234567890 # wireless-essid myssid # wireless-channel 4 I am not able to get the problem , please help me as I want the internet connection to my mini board for a purpose thank you
Hi Some of the Internet Connection Providers maintain a database of the mac address of their clients LAN card. In that case if you change your LAN card then also you will not be able to use your internet connection unless you ask your service provider to update the database. Try one thing - make a note of the MAC address of your PC's LAN card. assign the same MAC address to the mini2440 board and try once again. I think you might be able to use the internet connection this way. Regards linuxsupport@vectorindia.org http://www.vectorindia.org
hello thanks Linux_supporet I did what you suggested and I got the success in conne3cting to the network in my home. But when I tried to connect to the network at my college computer lab than I got the my mini dhcp client get the access to it but with some error , the output is this : Configuring network interfaces...Internet Systems Consortium DHCP Client V3.1.1 Copyright 2004-2008 Internet Systems Consortium. All rights reserved. For info, please visit http://www.isc.org/sw/dhcp/ eth1: link down Listening on LPF/eth1/00:23:54:a8:7f:26 Sending on LPF/eth1/00:23:54:a8:7f:26 Sending on Socket/fallback DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 7 eth1: link up, 100Mbps, full-duplex, lpa 0x45E1 DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 13 DHCPOFFER from 192.168.10.1 DHCPREQUEST on eth1 to 255.255.255.255 port 67 DHCPACK from 192.168.10.1 SIOCADDRT: No such process bound to 192.168.10.27 -- renewal in 12520317 seconds. done. everything is ok except this " SIOCADDRT: No such process " and I am not able to get this problem that why this is happening and also the result of my route -n command is as follows : # route -n Kernel IP routing table Destination Gateway Genmask Flags Metric Ref Use Iface 192.168.10.0 0.0.0.0 255.255.255.0 U 0 0 0 eth1 it does not show the entire route table also it get assigned the ip address automatically but not getting the pinging to any site : the ifconfig is this : ifconfig eth1 Link encap:Ethernet HWaddr 00:23:54:a8:7f:26 inet addr:192.168.10.27 Bcast:192.168.10.255 Mask:255.255.255.0 UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:304 errors:0 dropped:0 overruns:0 frame:0 TX packets:2 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:28517 (27.8 KiB) TX bytes:684 (684.0 B) Interrupt:51 Base address:0x300 lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 UP LOOPBACK RUNNING MTU:16436 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) Please help me linux_support I am not getting this . Thank you
Hello actually when I connect mini2440 to my home internet I get this as output through this command : # /etc/init.d/networking start Configuring network interfaces...Internet Systems Consortium DHCP Client V3.1.1 Copyright 2004-2008 Internet Systems Consortium. All rights reserved. For info, please visit http://www.isc.org/sw/dhcp/ eth1: link down Listening on LPF/eth1/00:1b:fc:c5:1a:12 Sending on LPF/eth1/00:1b:fc:c5:1a:12 Sending on Socket/fallback eth1: link up, 100Mbps, full-duplex, lpa 0x45E1 DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 7 DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 7 DHCPOFFER from 10.128.0.1 DHCPREQUEST on eth1 to 255.255.255.255 port 67 DHCPACK from 10.128.0.1 bound to 116.74.41.85 -- renewal in 378 seconds. done. there is no " SIOCADDRT: No such process " in the above connection but in my college I get this : Configuring network interfaces...Internet Systems Consortium DHCP Client V3.1.1 Copyright 2004-2008 Internet Systems Consortium. All rights reserved. For info, please visit http://www.isc.org/sw/dhcp/ eth1: link down Listening on LPF/eth1/00:23:54:a8:7f:26 Sending on LPF/eth1/00:23:54:a8:7f:26 Sending on Socket/fallback DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 7 eth1: link up, 100Mbps, full-duplex, lpa 0x45E1 DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 13 DHCPOFFER from 192.168.10.1 DHCPREQUEST on eth1 to 255.255.255.255 port 67 DHCPACK from 192.168.10.1 SIOCADDRT: No such process bound to 192.168.10.27 -- renewal in 12520317 seconds. done. everything is ok except this " SIOCADDRT: No such process " and I am not able to get this problem that why this is happening and also the result of my route -n command is as follows : # route -n Kernel IP routing table Destination Gateway Genmask Flags Metric Ref Use Iface 192.168.10.0 0.0.0.0 255.255.255.0 U 0 0 0 eth1 it does not show the entire route table whereas in my home network it shows this on route : route -n Kernel IP routing table Destination Gateway Genmask Flags Metric Ref Use Iface 116.74.40.0 0.0.0.0 255.255.248.0 U 0 0 0 eth1 0.0.0.0 116.74.40.1 0.0.0.0 UG 0 0 0 eth1 Please give me solution to this that what is this and how to get rid of this. Thank you
Hi That error means its some kind of routing error and your mini2440 cannot find the route to the server. Now since your mini2440 is connecting to your home network successfully then the settings in your 2440 is correct. I will suggest you to consult the administrator of your college LAN. Regards Vector Institute linuxsupport@vectorindia.org http://www.vectorindia.org
