Hi all, i have mini2440 board. Tplink tlwn 727n is working fine when it is plugged into usb port. I want to use usb mouse as well. So i bought one to four usb port connvertor. Now, tplink adapter and usb mouse both can be plugged into usb convertor ports. Usb mouse is working fine but tplink adapter is not working. Can anyone tell what can be the issue that tplink adapter not working with usb mouse when it is plugged into usb convertor??? Regards
USB MOUSE AND TPLINK ADAPTER
What happens if you start with the mini2440 OFF with the 4 port USB hub plugged in, turn mini2440 ON and after boot-up is finished then plug your mouse in? Does it work? Then do the same except plug in the Tplink. Then do the same plugging the mouse in first then the Tplink. Then do the same plugging the Tplink in first then the mouse. Think that covers all the combinations. I have seen similar behaviour on my 4 port USB setup. Maybe, kernels are set up differently or it might be a mdev/udev issue or a hotplug issue. Good luck!
