Hi all, I have recentelly goy my Tiny6410 and while getting in touch with it, I put Windows CE into the Flash NAND. When I decided to get back to Linux, I got stucked on bootloader downloading. I have tried files from DVD and my builds,none seems to be working. here what DNW tells me while I use SD to put the system to flash: Installing os 'LINUX' Download Bootloader... Skip block 0x1 Download Bootloader failed =================================== just to inform, my FriendlyARM.ini: #This line cannot be removed. by FriendlyARM(www.arm9.net) CheckOneButton=No Action=install OS= Linux VerifyNandWrite=No StatusType = Beeper| LED #################### Linux ##################### Linux-BootLoader = Linux/u-boot_nand-ram256.bin Linux-Kernel = Linux/zImage_n43 Linux-CommandLine = root=/dev/mtdblock2 rootfstype=yaffs2 init=/linuxrc console=ttySAC0,115200 Linux-RootFs-InstallImage = Linux/rootfs_qtopia_qt4.img Linux-RootFs-RunImage = Linux/rootfs_qtopia_qt4.ext3 Could it be some issue on Superboot? I used the SD_Flasher as suggested on www.armdevs.com. Thanks a lot.
Cannot load Linux/Android/Ubuntu to NAND.(Tiny6410)
Hi, sorry for my late answer. As i see "u-boot_nand-ram256.bin" didn't work for me also. Try the "u-boot_nand-ram128.bin" file. look at http://www.friendlyarm.net/forum/topic/2684 ;) Sash
