Hello, I'm trying to get a N43 screen working on my mini2440. I have no idea how I can add support for this screen to my kernel / filesystem. There are several images on the net which contains the N43 display (see Andahammer) but I want to create my own kernel and filesysteem. Can you guys give me some hints? Thanks, Danny
NEC 4.3" on Mini2440
http://www.friendlyarm.net/forum/topic/2575 I believe this support all displays, read the patch details. Dave
Danny, Sorry, I was just reading the patch name <0001-s3c2440-mini2440-Add-support-for-new-LCD-panels.patch> and thought it might be among them. Looking at the patch, as an example, might provide a path forward. Good luck! Dave
Well, the strange thing is that Andahammer sells the kit. (mini2440 + N43) The image preloaded on the mini2440. So its possible. Now I would like to know how! ;) I will start with the patch.. I do have the kit Andahammer sells, so can I find the files / settings on that device? Danny
Unless they supply the kernel source or the configuration for the kernel (and which kernel is it) and the patches for it I believe you are out of luck. They should supply that information. Did a DVD come with the kit? Ask them (Charles Springer posts quite often on the other forum) for it. The rootfs image you should be able to mount it on loopback and look through the file system. I don't think you'll find anything specific to your touchscreen there. There only seem to be a few variables to specify, according to that patch. Can you get the datasheet for the touchscreen and see if that information is in it? Dave
