Dear All, When I try to boot the linux from ARM1176jzf-s EB board, the linux kernel hangs at Freeing init memory: 88K. Could you please suggest me the right solution for this . Could you please find the log details below and suggest me accordingly. Address Name ------- ---- 0x40000000 SYSTEM.DAT 0x40010000 Boot_Monitor Flash Area Base 0x40040000 Address Name ------- ---- 0x40040000 u-boot_realview_eb 0x40080000 base_linux 0x40980000 uImage-2.6 Flash Area Base 0x44000000 Address Name ------- ---- 0x44000000 SYSTEM.DAT Flash Area Base 0x44040000 Intel/Sharp Extended Query Table at 0x010A Intel/Sharp Extended Query Table at 0x010A Intel/Sharp Extended Query Table at 0x010A Using buffer write method cfi_cmdset_0001: Erase suspend on write enabled 1 cmdlinepart partitions found on MTD device armflash.0 Creating 1 MTD partitions on "armflash.0": 0x00080000-0x004ae000 : "cramfs" mtd: partition "cramfs" doesn't end on an erase block -- force read-only mice: PS/2 mouse device common for all mice Advanced Linux Sound Architecture Driver Version 1.0.13 (Tue Nov 28 14:07:24 200 6 UTC). aaci-pl041 fpga:04: ARM AC'97 Interface at 0x0000000010004000, irq 51, fifo 512 input: AT Raw Set 2 keyboard as /class/input/input0 atkbd.c: keyboard reset failed on fpga:07 ALSA device list: #0: ARM AC'97 Interface at 0x0000000010004000, irq 51 TCP cubic registered NET: Registered protocol family 1 NET: Registered protocol family 17 VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 4 VFS: Mounted root (cramfs filesystem) readonly. Freeing init memory: 88K Thanks & Regards, Murali.
kernel hangs at freeing memory 88K
Hi murali this is forum for friendlyarm not other devices. Anyhow try add user_dbg=31 to kernel arguments to see where it hangs. marek
