tslib-1.4 install question ./autogen.sh outpu info: libtoolize: putting auxiliary files in `.'. libtoolize: copying file `./config.guess' libtoolize: copying file `./config.sub' libtoolize: copying file `./install-sh' libtoolize: copying file `./ltmain.sh' libtoolize: putting macros in `m4/internal'. libtoolize: copying file `m4/internal btool.m4' libtoolize: copying file `m4/internal/ltoptions.m4' libtoolize: copying file `m4/internal/ltsugar.m4' libtoolize: copying file `m4/internal/ltversion.m4' libtoolize: copying file `m4/internal/lt~obsolete.m4' libtoolize: Consider adding `AC_CONFIG_MACRO_DIR([m4])' to configure.ac and libtoolize: rerunning libtoolize, to keep the correct libtool macros in-tree. configure.ac:7: installing `./missing' THE ABOVE IS ALL THE INFO OUTPUT DO NOT HAVE THE INFO BELOW! Done . Aclocal . . . Done . Autoheader . . . Done . Automake . . . configure . ac : 21 : installing ` . / config . guess ' configure.ac:21: installing `./config.sub' configure . ac : 7 : installing ` . / install - sh ' configure.ac:7: installing `./missing' plugins / Makefile . am : installing ` . / depcomp Done. Autoconf...Done. Now you can do ./configure, make, make install. then the ts/bin/ts_calculate can be run in the s3c410 but in the qt4-arm installing there are errors : ts-init errors!!! please !!!thanks email:8053199668@qq.com
tslib-1.4
http://billforums.station51.net/viewtopic.php?f=8&t=15 Starts with a tutorial and ends with the way that worked for me. Dave
