Hello all, I tried opening the Touch Screen device with O_NONBLOCK option as I was thinking that application need not wait until there is data in touch screen. I have polling routine which is called periodically to check for data in the touch screen. When I opened the device with O_NONBLOCK I was getting continuous errors on my terminal stating that "ts device read error: resource temporarily unavailable". Then I removed the flag and program was running. Is there any help on how to use this flag O_NONBLOCK for devices? Thanks and regards Rajam QMAX Systems
MINI2440 - touch screen device open with O_NONBLOCK
I have provided the test code which we modified taking the base code from
the test routines available in the ts library.
int ghw_touch_init()
ts_dev = open("/dev/input/event0",O_RDONLY|O_NONBLOCK);
if (ts_dev < 0) {
printf("Touch screen driver: open device error!\n");
printf("errno = %d, %s\n", errno, strerror(errno));
return 0;
else {
printf (" Touch screen device opened successfully! \n");
return 1;
/*flush the ts device */
ts_flush(ts_dev);
Simulates a touch screen input.
Returns 1 if a touch change (an edge or pressed coordinate change) has
been detected
Returns 0 if the touch level is unchanged (unpressed, or pressed and
same position).
Edge = 1, Touch screen pressed changed state.
Edge = 0, No touch state change.
Level = 1, Touch screen pressed (x,y values is a (new) valid position)
Level = 0, No touch (x,y values is the position where last touch
stopped)
unsigned char ghwTouchGet(unsigned char *edgep, unsigned char *levelp, int
*xp, int *yp)
int nRet=0; // index;
static unsigned short oldx = 0;
static unsigned short oldy = 0;
int x;
int y;
struct ts_sample; // *ts_samples_data, ts_data;
screen_pressed=0;
/* read samples from touch screen device */
/*do {
if (ts_input_read(ts_dev, &ts_samples[0], 1) < 0) {
perror("ts_read");
//close_framebuffer ();
return;
} while (ts_samples[0].pressure == 0);
/* Now collect up to MAX_SAMPLES touches into the samp array. */
/* index = 0;
do {
if (index < MAX_SAMPLES-1)
index++;
if (ts_input_read(ts_dev, &ts_samples[index], 1) < 0) {
perror("ts_read");
return;
} while (ts_samples[index].pressure > 0);
printf("Took %d samples...\n",index);
getxy (ts_dev, &x, &y);
// printf ("After ts read: x=%d, y=%d \n", x, y);
/* check if x, y has changed from previous values
* update return values accordingly
if (screen_pressed == 0) {
*edgep = 0;
*levelp = 0;
*xp = oldx;
*yp = oldy;
return 0;
else {
*edgep = screen_pressed;
if (x != oldx || y != oldy) {
*levelp=1;
if (xp != NULL)
*xp = (int)(x*xres/x_ts_max);
if (yp != NULL)
*yp = (int) (y*yres/y_ts_max);
/* x = oldx; */ /* x pos */ /* we need to remap the touch screen
co-ordinates to frame buffer pixels */
/* y = oldy; */ /* y pos */
/* Change detection */
nRet = (screen_pressed != 0 || (x != oldx) || (y != oldy)) ? 1 : 0;
oldx = x;
oldy = y;
return nRet;
int ts_input_read (int ts_dev, struct ts_sample *samp, int nr)
struct input_event ev;
unsigned char *p = (unsigned char *) &ev;
int len = sizeof(struct input_event);
static struct ts_sample ts_temp;
int ret = nr;
int total = 0;
while (total < nr) {
ret = read(ts_dev, p, len);
if (ret == -1) {
if (errno == EINTR) {
continue;
break;
if (ret < (int)sizeof(struct input_event)) {
/* short read
* restart read to get the rest of the event
p += ret;
len -= ret;
continue;
// printf("type= %d, code= %d, value=0x%04x\n", ev.type, ev.code,
ev.value);
/*if event is SYNC event then dont have to record the x,y - just
continue reading */
if (ev.type == EV_SYN) continue;
/* successful read of a whole event */
if (ev.type == EV_ABS) {
switch (ev.code) {
case ABS_X:
if (ev.value != 0) {
samp->x = ts_temp.x = ev.value;
samp->y = ts_temp.y;
samp->pressure = ts_temp.pressure;
} else {/*flush the ts device */
fprintf(stderr, "tslib: dropped x = %d\n", ts_temp.x);
continue;
break;
case ABS_Y:
samp->x = ts_temp.x;
samp->y = ts_temp.y = ev.value;
} else {
fprintf(stderr, "tslib: dropped y = %d\n", ts_temp.y);
continue;
break;
case ABS_PRESSURE:
samp->pressure = ts_temp.pressure = ev.value;
samp->tv = ev.time;
break;
} /* end switch */
#ifdef DEBUG
fprintf(stderr, "RAW---------------------------> %d %d %d\n",
ts_temp.x, ts_temp.y, ts_temp.pressure);
#endif /* DEBUG */
samp++;
total++;
} else if (ev.type == EV_KEY) {
switch (ev.code) {
case BTN_TOUCH:
if (ev.value == 0) {
/* pen up */
samp->x = 0;
samp->y = 0;
samp->pressure = 0;
samp->tv = ev.time;
samp++;
total++;
break;
} /* end switch */
} else {
//fprintf(stderr, "tslib: Unknown event type %d\n", ev.type);
ret = total;
return (ret);
static int sort_by_x(const void* a, const void *b)
return (((struct ts_sample *)a)->x - ((struct ts_sample *)b)->x);
static int sort_by_y(const void* a, const void *b)
return (((struct ts_sample *)a)->y - ((struct ts_sample *)b)->y);
void getxy(int ts_dev, int *x, int *y)
struct ts_sample samp[MAX_SAMPLES];
int index, middle;
do {
if (ts_input_read(ts_dev, &samp[0], 1) < 0) {
perror("ts_read");
return;
} while (samp[0].pressure == 0);
index = 0;
do {
index++;
if (ts_input_read(ts_dev, &samp[index], 1) < 0) {
perror("ts_read");
return;
} while (samp[index].pressure > 0);
//printf("Took %d samples...\n",index);
if (!index) { screen_pressed=0; return; }
screen_pressed=1;
* At this point, we have samples in indices zero to (index-1)
* which means that we have (index) number of samples. We want
* to calculate the median of the samples so that wild outliers
* don't skew the result. First off, let's assume that arrays
* are one-based instead of zero-based. If this were the case
* and index was odd, we would need sample number ((index+1)/2)
* of a sorted array; if index was even, we would need the
* average of sample number (index/2) and sample number
* ((index/2)+1). To turn this into something useful for the
* real world, we just need to subtract one off of the sample
* numbers. So for when index is odd, we need sample number
* (((index+1)/2)-1). Due to integer division truncation, we
* can simplify this to just (index/2). When index is even, we
* need the average of sample number ((index/2)-1) and sample
* number (index/2). Calculate (index/2) now and we'll handle
* the even odd stuff after we sort.
middle = index/2;
if (x) {
qsort(samp, index, sizeof(struct ts_sample), sort_by_x);
if (index & 1)
*x = samp[middle].x;
else
*x = (samp[middle-1].x + samp[middle].x) / 2;
if (y) {
qsort(samp, index, sizeof(struct ts_sample), sort_by_y);
if (index & 1)
*y = samp[middle].y;
else
*y = (samp[middle-1].y + samp[middle].y) / 2;
