I am trying to compile buserror kernel but I have the following error : "/usr/local/angstrom/arm/libexec/gcc/arm-angstrom-linux-gnueabi/4.3.3/cc1: error while loading shared libraries: libmpfr.so.1: cannot open shared object file: No such file or directory" - some search point me to setting LD_LIBRARY_PATH to a path to this file, but with no sucess ... - I've also installed "libmpfr-dev" on the host but still the error If someone already faced that or has a clue ... thanks, David
Angstrom kernel compilation error
> "libmpfr.so.1: can not open shared object file: No such file or directory" It can not be drawn on inherited classes.
Dear Killerwatt, I've download the toolchain and extracted it, so how could directory structure be different ? Where should this file be ? thanks, David
Yes, you have download the chain. But is not the same. What you need is the same "struct", of PC from developer. Sorry for my English. I´m an old German.
May be there is a different path to a nother partition like e:// or higher. You have to take a look therefore.
