Hello, Maybe somebody used Bluetooth with this board ? I need to program communication with PC. I recently read an article about bluetooth where some guy has been communicating with bluetooth module like with normal Serial port. Maybe somebody could tell me , from where I should start with this idea ? On the net shops, we can find a lot of bluetooth modules for PC but to be honest i don't know if there is possibility to use them with mini2440. Maybe somebody tried to communicate with bluetooth using mini2440 ? There so much stuff,and I am getting more and more confused, so what do you think ? Can you help me a little ? Best Regards, Robert
mini2440 + Bluetooth
On the PC side you could use a normal usb bluetooth adapter which supports SPP (Serial Port Profile) Then, on the mini2440 side you can use a bluetooth to serial adapter which will effectively allow you to communicate as if it was connected with rs232 cable. There are several solutions for this on the market, one of which I have used is the KC21 from http://kcwirefree.com/data.html - they sell samples for $36 But there are many different ones available... search for "bluetooth module" on google and ebay... Another option is to see which usb adapters are supported by the latest kernel, compile it and use normal bluetooth adapters on both ends.
Thanks ! I think , I will try to use Win CE 6.0 first. Do you think there is a possibility to connect this module to the smartphone with Android ? :-)
