Hey all. I did quite a lot of work on the camera of the 2440. I now would like to run the software I wrote on the 6410, but I need the CMOS camera to run at 320x240. For the 2440 I changed the driver in the kernel, for the 6410 I saw that there is setting in menuconfig which allows to change the res. When I recompile the kernel and upload it however, the camera is still running at 640x480. Has anyone successfully changed the res of the camera? Thanks a mil Cheers Paolo
Mini6410 camera resolution change
Hi Paolo, just ignore each odd or even pixel in a row and do the same for the rows you will have to write some code for that and isn't verry neet, but it does the trick.
