I bought this LCD 4.3 from here : http://www.andahammer.com/mini43-sdk/ Can somebody please tell me what setting to use in options.h //#define LCD_N35 //#define LCD_L80 #define LCD_T35 //#define LCD_A70 //#define LCD_VGA1024768 Is there a setting to change the default orientation of the screen ? Thanks.
Mini2440 with 4.3 LCD
Well if you post datasheet we can add support for you display. With current setup your display will not work. marekk
This is the datasheet link: http://www.sparkfun.com/datasheets/LCD/LCD-08335-1.pdf I also require support for it( either this one or 'NEC 4.3" TFT LCD' mentioned in the downloads page ). Thanks a lot!!!
I am also interested in support for 4.3" touch screen. There are a few places to look for: in options.h you must add: #elif defined(LCD_N43) #define LCD_WIDTH 480 #define LCD_HEIGHT 272 in s3c2440a_lcd.h you must add: #elif defined(LCD_N43) #define LCD_PIXCLOCK .. #define LCD_RIGHT_MARGIN .. #define LCD_LEFT_MARGIN .. #define LCD_HSYNC_LEN .. #define LCD_UPPER_MARGIN .. #define LCD_LOWER_MARGIN .. #define LCD_VSYNC_LEN .. in platform.reg: HKEY_LOCAL_MACHINE\HARDWARE\DEVICEMAP\TOUCH on CalibrationData you must modify or delete the current numbers. What I did so far: copied from N35 to N43 settings in s3c2440a_lcd.h. Looks ok but needs few adjustments, also calibration numbers are far from correct. Building the nk.bin file takes some time but in time and if nobody will work on it I will post here my results.
