I use the linux driver easycapdc60 for FriendlyARM Tiny6410. When used with mencoder, I do not get even a frame from the video capture device. Any help will be appreciated. Below is the diagnostic message : <7>easycap:: easycap_open: ==========OPEN========= <7>easycap::0adjust_standard: selected standard: PAL_BGHIN <7>easycap::0adjust_format: sought: 640x480,UYVY(0x59565955),1=field,0x00=std mask <7>easycap::0adjust_format: sought: V4L2_FIELD_NONE <7>easycap::0adjust_format: actioning: 640x480 PAL_BGHIN_AT_640x480_FMT_UYVY-n <7>easycap::0adjust_brightness: adjusting brightness to 0x7F <7>easycap::0adjust_contrast: adjusting contrast to 0x3F <7>easycap::0adjust_saturation: adjusting saturation to 0x2F <7>easycap::0adjust_hue: adjusting hue to 0x00 <7>easycap::0adjust_format: sought: 640x480,UYVY(0x59565955),1=field,0x00=std mask <7>easycap::0adjust_format: sought: V4L2_FIELD_NONE <7>easycap::0adjust_format: actioning: 640x480 PAL_BGHIN_AT_640x480_FMT_UYVY-n <7>easycap::0adjust_format: sought: 640x480,YV12(0x32315659),0=field,0x00=std mask <7>easycap::0adjust_format: sought: V4L2_FIELD_ANY <7>easycap::0adjust_format: prefer: V4L2_FIELD_NONE=field, was V4L2_FIELD_ANY <7>easycap::0adjust_format: cannot do: 640x480 with standard mask 0x00 <7>easycap::0adjust_format: cannot do 640x... with standard mask 0x00 <7>easycap::0adjust_format: cannot do ...x480 with standard mask 0x00 <7>easycap::0adjust_format: 640x480 unmatched <7>easycap::0easycap_ioctl: requested input already in effect <7>easycap::0adjust_standard: selected standard: PAL_BGHIN <7>easycap::0adjust_standard: requested standard already in effect <7>easycap::0adjust_format: sought: 60x40,UYVY(0x59565955),0=field,0x00=std mask <7>easycap::0adjust_format: sought: V4L2_FIELD_ANY <7>easycap::0adjust_format: prefer: V4L2_FIELD_NONE=field, was V4L2_FIELD_ANY <7>easycap::0adjust_format: cannot do: 60x40 with standard mask 0x00 <7>easycap::0adjust_format: actioning: 320x240 PAL_BGHIN_AT_320x240_FMT_UYVY-n <7>easycap::0adjust_format: sought: 60x240,UYVY(0x59565955),1=field,0x00=std mask <7>easycap::0adjust_format: sought: V4L2_FIELD_NONE <7>easycap::0adjust_format: cannot do: 60x240 with standard mask 0x00 <7>easycap::0adjust_format: actioning: 320x240 PAL_BGHIN_AT_320x240_FMT_UYVY-n <7>easycap::0adjust_format: sought: 320x40,UYVY(0x59565955),0=field,0x00=std mask <7>easycap::0adjust_format: sought: V4L2_FIELD_ANY <7>easycap::0adjust_format: prefer: V4L2_FIELD_NONE=field, was V4L2_FIELD_ANY <7>easycap::0adjust_format: cannot do: 320x40 with standard mask 0x00 <7>easycap::0adjust_format: actioning: 320x240 PAL_BGHIN_AT_320x240_FMT_UYVY-n <7>easycap::0adjust_mute: adjusting mute: 0=peasycap->audio_idle <7>easycap::0adjust_brightness: unchanged brightness at 0x7F <7>easycap::0adjust_hue: unchanged hue at 0x80 <7>easycap::0adjust_saturation: unchanged saturation at 0xAF <7>easycap::0adjust_contrast: unchanged contrast at 0xBF <7>easycap::0easycap_complete: easycap driver shutting down on condition green <7>easycap::0adjust_standard: selected standard: PAL_BGHIN <7>easycap::0adjust_format: sought: 320x240,UYVY(0x59565955),1=field,0x00=std mask <7>easycap::0adjust_format: sought: V4L2_FIELD_NONE <7>easycap::0adjust_format: actioning: 320x240 PAL_BGHIN_AT_320x240_FMT_UYVY-n <7>easycap::0adjust_brightness: adjusting brightness to 0x7F <7>easycap::0adjust_contrast: adjusting contrast to 0x3F <7>easycap::0adjust_saturation: adjusting saturation to 0x2F <7>easycap::0adjust_hue: adjusting hue to 0x00 <7>easycap::0easycap_complete: easycap driver shutting down on condition green <7>easycap::0adjust_standard: selected standard: PAL_BGHIN <7>easycap::0adjust_format: sought: 320x240,UYVY(0x59565955),1=field,0x00=std mask <7>easycap::0adjust_format: sought: V4L2_FIELD_NONE <7>easycap::0adjust_format: actioning: 320x240 PAL_BGHIN_AT_320x240_FMT_UYVY-n <7>easycap::0adjust_brightness: adjusting brightness to 0x7F <7>easycap::0adjust_contrast: adjusting contrast to 0x3F <7>easycap::0adjust_saturation: adjusting saturation to 0x2F <7>easycap::0adjust_hue: adjusting hue to 0x00 success: format: 9 data: 0x0 - 0x0easycap:: easycap_open: ==========OPEN========= TV file format detected. Selected driver: v4l2 name: Video 4 Linux 2 input author: Martin Olschewski <olschewski@zpr.uni-koeln.de> comment: first try, more to come ;-) easycap::0adjust_standard: selected standard: PAL_BGHIN easycap::0adjust_format: sought: 320x240,UYVY(0x59565955),1=field,0x00=std mask easycap::0adjust_format: sought: V4L2_FIELD_NONE easycap::0adjust_format: actioning: 320x240 PAL_BGHIN_AT_320x240_FMT_UYVY-n easycap::0adjust_brightness: adjusting brightness to 0x7F easycap::0adjust_contrast: adjusting contrast to 0x3F easycap::0adjust_saturation: adjusting saturation to 0x2F easycap::0adjust_hue: adjusting hue to 0x00 Selected device: EasyCAP DC60 Capabilities: video capture audio read/write streaming easycap::0adjust_format: sought: 640x480,UYVY(0x59565955),1=field,0x00=std mask easycap::0adjust_format: sought: V4L2_FIELD_NONE easycap::0adjust_format: actioning: 640x480 PAL_BGHIN_AT_640x480_FMT_UYVY-n supported norms: 0 = PAL_BGHIN; 1 = NTSC_N_443; 2 = PAL_Nc; 3 = NTSC_N; 4 = SECAM; 5 = NTSC_M; 6 = NTSC_M_JP; 7 = PAL_60; 8 = NTSC_443; 9 = PAL_M; 10 = PAL_BGHIN_SLOW;; inputs: 0 = CVBS0; 1 = CVBS1; 2 = CVBS2; 3 = CVBS3; 4 = CVBS4; 5 = S-VIDEO; Current input: 0 Current format: UYVY easycap::0adjust_format: sought: 640x480,YV12(0x32315659),0=field,0x00=std mask easycap::0adjust_format: sought: V4L2_FIELD_ANY easycap::0adjust_format: prefer: V4L2_FIELD_NONE=field, was V4L2_FIELD_ANY easycap::0adjust_format: cannot do: 640x480 with standard mask 0x00 easycap::0adjust_format: cannot do 640x... with standard mask 0x00 easycap::0adjust_format: cannot do ...x480 with standard mask 0x00 easycap::0adjust_format: 640x480 unmatched one_wire_status: 2 easycap::0easycap_ioctl: requested input already in effect easycap::0adjust_standard: selected standard: PAL_BGHIN easycap::0adjust_standard: requested standard already in effect easycap::0adjust_format: sought: 60x40,UYVY(0x59565955),0=field,0x00=std mask one_wire_status: 4 easycap::0adjust_format: sought: V4L2_FIELD_ANY easycap::0adjust_format: prefer: V4L2_FIELD_NONE=field, was V4L2_FIELD_ANY easycap::0adjust_format: cannot do: 60x40 with standard mask 0x00 one_wire_status: 4 easycap::0adjust_format: actioning: 320x240 PAL_BGHIN_AT_320x240_FMT_UYVY-n tv.c: norm_from_string(pal): Bogus norm parameter, setting default. easycap::0adjust_format: sought: 60x240,UYVY(0x59565955),1=field,0x00=std mask easycap::0adjust_format: sought: V4L2_FIELD_NONE easycap::0adjust_format: cannot do: 60x240 with standard mask 0x00 easycap::0adjust_format: actioning: 320x240 PAL_BGHIN_AT_320x240_FMT_UYVY-n easycap::0adjust_format: sought: 320x40,UYVY(0x59565955),0=field,0x00=std mask easycap::0adjust_format: sought: V4L2_FIELD_ANY easycap::0adjust_format: prefer: V4L2_FIELD_NONE=field, was V4L2_FIELD_ANY easycap::0adjust_format: cannot do: 320x40 with standard mask 0x00 easycap::0adjust_format: actioning: 320x240 PAL_BGHIN_AT_320x240_FMT_UYVY-n one_wire_status: 2 Selected input hasn't got a tuner!easycap::0adjust_mute: adjusting mute: 0=peasycap->audio_idle easycap::0adjust_brightness: unchanged brightness at 0x7F easycap::0adjust_hue: unchanged hue at 0x80 easycap::0adjust_saturation: unchanged saturation at 0xAF easycap::0adjust_contrast: unchanged contrast at 0xBF one_wire_status: 4 [V] filefmt:9 fourcc:0x59565955 size:320x240 fps:60.000 ftime:=0.0167 Opening video filter: [expand osd=1] Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1 ========================================================================== Opening video decoder: [raw] RAW Uncompressed Video Could not find matching colorspace - retrying with -vf scale... Opening video filter: [scale] Movie-Aspect is undefined - no prescaling applied. [swscaler @ 0x8d35a8]using unscaled uyvy422 -> yuv420p special converter videocodec: libavcodec (320x240 fourcc=47504a4d [MJPG]) Selected video codec: [rawuyvy] vfm: raw (RAW UYVY) ========================================================================== Forcing audio preload to 0, max pts correction to 0. Skipping frame! Pos: 0.0s 1f ( 0%) 0.48fps Trem: 0min 0mb A-V:0.000 [0:0] Skipping frame! Pos: 0.0s 2f ( 0%) 0.64fps Trem: 0min 0mb A-V:0.000 [0:0] Skipping frame! Pos: 0.0s 3f ( 0%) 0.72fps Trem: 0min 0mb A-V:0.000 [0:0] Skipping frame! Pos: 0.0s 4f ( 0%) 0.77fps Trem: 0min 0mb A-V:0.000 [0:0] Skipping frame! ^C^C^C 0.0s 5f ( 0%) 0.80fps Trem: 0min 0mb A-V:0.000 [0:0] Skipping frame! Pos: 0.0s 6f ( 0%) 0.83fps Trem: 0min 0mb A-V:0.000 [0:0] Flushing video frames. Writing index... Writing header... ODML: Aspect information not (yet?) available or unspecified, not writing vprp header. Video stream: nan kbit/s (0 B/s) size: 0 bytes nan secs 6 frames ^[[A^[[A^[[A^[[A^[[A^[[A^[[A^[[A^[[A^[[A^[[A^[[A^[[Aeasycap::0easycap_complete: easycap driver shutting down on condition green easycap::0adjust_standard: selected standard: PAL_BGHIN easycap::0adjust_format: sought: 320x240,UYVY(0x59565955),1=field,0x00=std mask easycap::0adjust_format: sought: V4L2_FIELD...stripped-down
easycapdc60
Hi Pratik, thanks for your reply. Installed on board is a linux distribution from FriendlyARM based on the kernel linux-2.6.36. I have tested easycap hardware and the easycapdc60 drivers on my desktop Fedora14 with success. Hence any hardware fault is ruled out. On Fedora14 desktop, I compile the easycap driver as VIDEODEV client, and then later an independent module. Both way works for Fedora14. I did the same for my board, but without success. On the board, the output from mencoder and from log file are as described in the first post. In this way, I rule out fault due to dependency on VIDEODEV module. I have already turned the DEBUG level in the install.sh script to LEVEL 9, and based on the debug message, I have no clue how to proceed on. At this point, I am running out of ideas where to look for faults. Any advice will be appreciated. Thanks.
To be more concrete, Mencoder is used to capture video through easycapdc60. FriendlyARM tiny6410 is an ARM device. Easycap is installed as an independent module and appears as /dev/easycap0. Any help will be appreciated. <Run> ./mencoder tv:// -tv driver=v4l2:width=60:height=40:fps=25:device=/dev/easycap0 -nosound -ovc lavc -lavcopts vcodec=mjpeg -o ~/easycap_video.avi <output from mencoder> Output from mencoder : MEncoder SVN-r32819-snapshot-4.4.3 (C) 2000-2011 MPlayer Team success: format: 9 data: 0x0 - 0x0 TV file format detected. Selected driver: v4l2 name: Video 4 Linux 2 input author: Martin Olschewski <olschewski@zpr.uni-koeln.de> comment: first try, more to come ;-) Selected device: EasyCAP DC60 Capabilities: video capture audio read/write streaming supported norms: 0 = PAL_BGHIN; 1 = NTSC_N_443; 2 = PAL_Nc; 3 = NTSC_N; 4 = SE; inputs: 0 = CVBS0; 1 = CVBS1; 2 = CVBS2; 3 = CVBS3; 4 = CVBS4; 5 = S-VIDEO; Current input: 0 Current format: UYVY tv.c: norm_from_string(pal): Bogus norm parameter, setting default. Selected input hasn't got a tuner! [V] filefmt:9 fourcc:0x59565955 size:320x240 fps:25.000 ftime:=0.0400 Opening video filter: [expand osd=1] Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1 ========================================================================== Opening video decoder: [raw] RAW Uncompressed Video Could not find matching colorspace - retrying with -vf scale... Opening video filter: [scale] Movie-Aspect is undefined - no prescaling applied. [swscaler @ 0x8d35a8]using unscaled uyvy422 -> yuv420p special converter videocodec: libavcodec (320x240 fourcc=47504a4d [MJPG]) Selected video codec: [rawuyvy] vfm: raw (RAW UYVY) ========================================================================== Forcing audio preload to 0, max pts correction to 0. Skipping frame! Pos: 0.0s 1f ( 0%) 0.48fps Trem: 0min 0mb A-V:0.000 [0:0] Skipping frame! Pos: 0.0s 2f ( 0%) 0.64fps Trem: 0min 0mb A-V:0.000 [0:0] Skipping frame! Pos: 0.0s 3f ( 0%) 0.72fps Trem: 0min 0mb A-V:0.000 [0:0] ^C Skipping frame! Pos: 0.0s 4f ( 0%) 0.77fps Trem: 0min 0mb A-V:0.000 [0:0] Flushing video frames. Writing index... Writing header... ODML: Aspect information not (yet?) available or unspecified, not writing vprp . Video stream: nan kbit/s (0 B/s) size: 0 bytes nan secs 4 frames v4l2: 1 frames successfully processed, 0 frames dropped. <Output in message log> easycap:: easycap_open: ==========OPEN========= easycap::0adjust_standard: selected standard: PAL_BGHIN easycap::0adjust_format: sought: 640x480,UYVY(0x59565955),1=field,0x00=std mk easycap::0adjust_format: sought: V4L2_FIELD_NONE easycap::0adjust_format: actioning: 640x480 PAL_BGHIN_AT_640x480_FMT_UYVY-n easycap::0adjust_brightness: adjusting brightness to 0x7F easycap::0adjust_contrast: adjusting contrast to 0x3F easycap::0adjust_saturation: adjusting saturation to 0x2F easycap::0adjust_hue: adjusting hue to 0x00 easycap::0adjust_format: sought: 640x480,UYVY(0x59565955),1=field,0x00=std mk easycap::0adjust_format: sought: V4L2_FIELD_NONE easycap::0adjust_format: actioning: 640x480 PAL_BGHIN_AT_640x480_FMT_UYVY-n easycap::0adjust_format: sought: 640x480,YV12(0x32315659),0=field,0x00=std mk easycap::0adjust_format: sought: V4L2_FIELD_ANY easycap::0adjust_format: prefer: V4L2_FIELD_NONE=field, was V4L2_FIELD_ANY easycap::0adjust_format: cannot do: 640x480 with standard mask 0x00 easycap::0adjust_format: cannot do 640x... with standard mask 0x00 easycap::0adjust_format: cannot do ...x480 with standard mask 0x00 easycap::0adjust_format: 640x480 unmatched easycap::0easycap_ioctl: requested input already in effect easycap::0adjust_standard: selected standard: PAL_BGHIN easycap::0adjust_standard: requested standard already in effect easycap::0adjust_format: sought: 60x40,UYVY(0x59565955),0=field,0x00=std mask easycap::0adjust_format: sought: V4L2_FIELD_ANY easycap::0adjust_format: prefer: V4L2_FIELD_NONE=field, was V4L2_FIELD_ANY easycap::0adjust_format: cannot do: 60x40 with standard mask 0x00 easycap::0adjust_format: actioning: 320x240 PAL_BGHIN_AT_320x240_FMT_UYVY-n easycap::0adjust_format: sought: 60x240,UYVY(0x59565955),1=field,0x00=std mak easycap::0adjust_format: sought: V4L2_FIELD_NONE easycap::0adjust_format: cannot do: 60x240 with standard mask 0x00 easycap::0adjust_format: actioning: 320x240 PAL_BGHIN_AT_320x240_FMT_UYVY-n easycap::0adjust_format: sought: 320x40,UYVY(0x59565955),0=field,0x00=std mak easycap::0adjust_format: sought: V4L2_FIELD_ANY easycap::0adjust_format: prefer: V4L2_FIELD_NONE=field, was V4L2_FIELD_ANY easycap::0adjust_format: cannot do: 320x40 with standard mask 0x00 easycap::0adjust_format: actioning: 320x240 PAL_BGHIN_AT_320x240_FMT_UYVY-n easycap::0adjust_mute: adjusting mute: 0=peasycap->audio_idle easycap::0adjust_brightness: unchanged brightness at 0x7F easycap::0adjust_hue: unchanged hue at 0x80 easycap::0adjust_saturation: unchanged saturation at 0xAF easycap::0adjust_contrast: unchanged contrast at 0xBF easycap::0easycap_complete: easycap driver shutting down on condition green easycap::0adjust_standard: selected standard: PAL_BGHIN easycap::0adjust_format: sought: 320x240,UYVY(0x59565955),1=field,0x00=std mk easycap::0adjust_format: sought: V4L2_FIELD_NONE easycap::0adjust_format: actioning: 320x240 PAL_BGHIN_AT_320x240_FMT_UYVY-n easycap::0adjust_brightness: adjusting brightness to 0x7F easycap::0adjust_contrast: adjusting contrast to 0x3F easycap::0adjust_saturation: adjusting saturation to 0x2F easycap::0adjust_hue: adjusting hue to 0x00 easycap::0easycap_complete: easycap driver shutting down on condition green easycap::0adjust_standard: selected standard: PAL_BGHIN easycap::0adjust_format: sought: 320x240,UYVY(0x59565955),1=field,0x00=std mk easycap::0adjust_format: sought: V4L2_FIELD_NONE easycap::0adjust_format: actioning: 320x240 PAL_BGHIN_AT_320x240_FMT_UYVY-n easycap::0adjust_brightness: adjusting brightness to 0x7F easycap::0adjust_contrast: adjusting contrast to 0x3F easycap::0adjust_saturation: adjusting saturation to 0x2F easycap::0adjust_hue: adjusting hue to 0x00 easycap::0adjust_mute: adjusting mute: 1=peasycap->audio_idle
Hi Pratik, I have received a reply from the easycapdc60 driver author. He suggested that I should check if my ARM board's USB host is 2.0, as easycap only works with USB2.0. It turns out that the USB host on TIny6410 board is USB1.1. >_<! That explains why I can not get any valid USB data stream from the video capture device~ Do you think if there is any FriendlyARM product with USB2.0 host?
Dear hunglun, I am using Mini2440. I am also getting green frames only. I have tried with mplayer. Do you get these two things after plugging EasyCapDC60? 1. /dev/easycap0 having link to /dev/video0 2. /proc/asound/EasyALSA0 If you dont get EasyALSA0 then you have to check the udev rules for easycap. You might have downloaded driver source from sourceforge, you can find in that see #----------------------------------------------------------------------------- # WRITE CONFIGURATION FILE(S) FOR udev #-------------------------------------------------------------------------- section in install.sh My another question, is your board able to play video files without any problem? I'm trying these things since last month.
Hi Pratik, easycap module can be compiled as VIDEODEV client or as an independent module. This option can be chosen in the install.sh : CLIENT = 0 When insmod the VIDEODEV client version of easycap module, /dev/video2 appears on my system. When I insmod the independent version of the module, it appears instead as /dev/easycap0. I did not pay attention to the sound part, as I just want to record video without sound. As for playing video, I can actually play a sample video using the built-in video player on Tiny6410. It is a mpeg video. Strangely, those video I made myself on desktop in avi format can not be played on Tiny6410. My problem lies more with the hardware part; USB1.1 host seems to be too slow for the minimum resolution that easycap offers.
Dear hunglun, I have tried with mplayer I got only green screen. Then I tried with gstreamer it is working but not showing on display. Do you have any idea how to add USB 2.0 ob board or Do we need to look for other development board? Thanks
Hi Pratik, as I am having problem with using easycapdc60 on my USB1.1 host, the options I have seem to be: 1. get another A/V to USB converter that support USB1.1 2. get a board with USB2.0 host 3. develop/find for easycapdc60 another driver that support USB1.1 Option 3 is probably the most time consuming. Option 2 is probably more expensive than option 1. I intend to find out more about option 3; see if it is too difficult to get another driver that support USB1.1 Regarding your problem getting mplayer to work with easycapdc60, you have a few suggestions: 1. have you got mplayer and easycapdc60 to work on desktop linux? it is always easier to get it work on desktop first, before cross-compiling it for ARM architecture. 2. try to look at the debugging message output by easycapdc60. Use "dmesg". You may find out more about the cause of the problem. Good luck!
Dear hunglun, I want to use Easycap DC60 as it is very cheap compared to others. And we dont have another driver that supports USB1.1 host. So I am looking for some other board which will give me necessary things. I have tested EasyCap and Mplayer on my desktop. It works perfect. My dmesg output is also fine, so no issues with driver but only that USB1.1 Thanks
Dear hunglun, I could find a same board having same things http://www.quickembed.com/Tools/Shop/ARM/200908/43.html have a look.
hello hunglun/Pratik, Can you please tell us how did you compile easycap for mini6410. I tried it without any success. Thanks and regards, Prathamesh.
Prathamesh, It requires USB2.0, It will not work on USB1.1 though you can compile it successfully and insert Kernel module. You can use following link: http://www.farlock.org/sheevaplug/sheevaplug-non-standard-module-compiling/
