I build the win ce 5.0 image with serila port support but my com1 does not work. is there any way to enable com1 ? Thanks
COM1 not work
The COM1 on my mini2440 not works. The COM ports of my computer are working. i write a program to test com ports of mini2440. when i want to open the com1 on Mini2440 it returns an error. but all other ports are function properly.
When i run my program on mini-2440 it says "COM1 does not exist" i check NOSERIAL and KITL UART but the problem is still exits. any one can help me ?
Monitored once the variables in the debugger. When reading the source code is overlooked quick little different spelling.
Right! You can also include more than redirect to 'COM1' or whatever. These are experiences that I often do myself. Because ultimately, even when you know what, in the source code is available.
