I am using a toolchain, in my linux machine, based on buildroot, to compile for the mini2440. I have luck and got to compile one small application to test in my mini2440. I cross-compiled using this command (the project is test1): ssaguiar@ssaguiar:~/build2440/buildroot-2011.02/output/build/qt-everywhere-opens ource-src-4.7.1/demos/test$/home/ssaguiar/build2440/buildroot-2011.02/output/bui ld/qt-everywhere-opensource-src-4.7.1/bin/qmake -spec /home/ssaguiar/build2440/buildroot-2011.02/output/build/qt-everywhere-opensource -src-4.7.1/mkspecs/qws/linux-arm-g++ o "/home/ssaguiar/build2440/buildroot-2011.02/output/build/qt-everywhere-open source-src-4.7.1/./demos/test1" "/home/ssaguiar/build2440/buildroot-2011.02/output/build/qt-everywhere-open source-src-4.7.1/demos/test1/test1.pro" Following the command above, I execute make in the test1 project´s folder and get the executable test1. The problem is when I put the program in the mini2440 root folder, change it to execute (chmod 777), I get this error: "tes1 not found" I think that this can be caused by the uClib version (in the buildroot I have downloaded, the version is: uClibc C library Version (uClibc 0.9.31.x) Can anybody help? Thanks
Compiling QT app for mini2440
Sorry, there´s an error in the post Change: The problem is when I put the program in the mini2440 root folder, change it to execute (chmod 777), I get this error: "tes1 not found" to: The problem is when I put the program in the mini2440 root folder, change it to execute (chmod 777), and call it, I get this error: "test1 not found"
The problem is exactly what he says it is: there is something not found! Run: 'ldd test1' on your mini2440 to get the info you need! Goodluck!
You see this kind of message, when a required shared library is not available at runtime. Run the "readelf" tool from your cross toolchain on your 'test1' executable first. It will output a list of share libraries marked as "(NEEDED)". All these libraries must be present on your target to make 'test1' run.
