Is there sombebody was trying to make 1wire implementation?
1Wire interface
work ok for me, the only "problem" is that the mini2440 gpio is possible only 3,3V and not 5v tolerant. if you are goinig to work with long cables, and use the 5V pin, you canīt work with pullup resistors on the gpio pin. i got a dalles sensor on a 35m cat5 cable, and 3,3v with pullup donīt work. or 2x 4m cat5 cable with 2 and 3 sensors also donīt work reliable with 3,3V and 4k7 or 2,2k pullups. a support question if any gpio pins are 5v toerant have been dropt at samsung, still waiting for a answer. greets Rudolf
Hi Rudolf, Please can you explain more what you use ? i try to write my own application in VB.NET .. thanks, regards
Damned !... nobody can share a sample project under VS2008 working under winCE 6.0 ? thanks in advance
MM Mario you find a way ?... my project is stopped since many days !... can't to communicate with my 1Wire lan :( i have try all the ways provide by Maxim and OWdotNET .. nothing successful :( please any suggestions ?.. thanks phil
good night anyone knows the 1 wire management protocol to wince, to measure the temperature of a sensor, DS1820. Thank you very much ..
