Guys, Yesterday I made a simple driver based off of code that was in the mini2440 chinese manual. It's a simple interrupt for one pin on the GPIO. I have researched how to compile and install device drivers on my current Linux system without re-compiling the kernel. As you know, in order for my driver to work on the mini2440 I have to cross compile it. I am a little unlear on how to do this. I sent my driver C file to the arm board and also a simple Makefile script to the board as well. When I type "make", it says that the make command is not found on the arm board. So, how do I go about installing the make command on the arm board? Or what commands do I use to compile this driver in general? I just need to be able to get the ".ko" file and use the "insmod" command to insert it into the mini2440 kernel, and then use other commands to get my own driver folder to show up in the "/dev" directory. Any help would be apperciated. Thanks you! -Ben
Compiling Device Driver Against ARM Linux
I have tried the command arm-linux-gcc mydriver.c mydriver Everything compiles correctly, but it creates a binary file for me... I need to compile it to where it gives me a ".ko" file. Any help would be appreciated. -Ben
Use the google translator in this link: http://www.sergioprado.org/2010/12/30/mini2440-compilando-aplicacoes-e-d...
Abuda, From a very fast translation and overview of this tutorial, it seems like it should work. I will try this as soon as possible. Thank you so much! Any other suggestions from anyone else are appreciated. -Ben
I am having an error when running make. /home/team3/Desktop/InterruptsTest/interrupt_driver.c:35: error: 'S3C2410_GPG0' undeclared here (not in a function) /home/team3/Desktop/InterruptsTest/interrupt_driver.c:36: error: 'S3C2410_GPG3' undeclared here (not in a function) /home/team3/Desktop/InterruptsTest/interrupt_driver.c:37: error: 'S3C2410_GPG5' undeclared here (not in a function) /home/team3/Desktop/InterruptsTest/interrupt_driver.c:38: error: 'S3C2410_GPG7' undeclared here (not in a function) /home/team3/Desktop/InterruptsTest/interrupt_driver.c:39: error: 'S3C2410_GPG6' undeclared here (not in a function) /home/team3/Desktop/InterruptsTest/interrupt_driver.c:40: error: 'S3C2410_GPG11' undeclared here (not in a function) I feel like I am missing a header file but I am unsure of which one. I can post my code if needed. Thanks.. -Ben
The macro is defined in the file linux/arch/arm/mach-s3c2410/include/mach/regs-gpio.h So, you need to use #include <mach/regs-gpio.h> in your file to resolve this error - Neo
HI abuda, the site you mention(http://www.sergioprado.org/2010/12/30/mini2440-compilando-aplicacoes-e-d...) was not in english. plz refer any site which is in english.
