BIOS not appeared
Raman 2011-03-21 16:01:54 Link
In my micro2440 board, BIOS screen is not appeared on power with switch(S2)
on NOR position. i have checked with two different serial port cable. on
power up DNW screen shows [COM1,115200bps][USB:Ok].if anybody knows
solution for this problem. please post it on forum.
davef 2011-03-22 10:33:16 Link
Possibly you have lost Supervivi in NOR.
Good opportunity to learn how to use H-JTAG.
http://www.friendlyarm.net/dl.php?file=hjtag-100.zip
And there is a HowTo called JTAGing the NOR found at www.andahammer.com
Good luck!
Dave
Raman 2011-03-23 15:05:40 Link
Hi davef
          Thank you for your reply. i J_TAGEd the supervii-64M,it is
working. now i am able to see BIOS menus. also i have loaded linux. it is
working but icon names in chinish chracter. is there any other image for
engish icon for linux.
Andreas Watterott 2011-03-23 15:26:57 Link
You can change the language here:
http://code.google.com/p/friendlyarm/wiki/Qt
nision 2011-04-12 11:24:07 Link
today, i find that my mini2440 have this problem also,but my supervivi have
not lost ,what can i do .another problem ,how can i use tftp to download my
u-boot ?
Ranjith 2011-08-03 13:37:16 Link
Hello, I have developed a similar board as mini2440 every component is
same, but as mini2440 comes with a pre-loaded BIOS, can anyone tell me how
do I load BIOS into the MCU ?
davef 2011-08-03 22:59:46 Link
My answer is above!
ranjith george 2011-08-05 11:58:19 Link
Hello Everyone,
           Thank you very much  DAVEF it worked, I have one more query the
board I am developing in that I had to implement wireless connectivity like
GPS and Wi-Fi, for this I got a multifunction radio Chip Wilink 7.0 from
TI, as I am using SC32442b Samsung processor, TI did not provide me the
drivers for this processors they gave me for OMAP4 , but I found Linux
drivers for Wilink 7.0 to SC32442 from openlink.org, the problem is I want
to run Windows CE 6.0 on my board , how do I import the drivers or how can
I port the available drivers ? coz writing a new driver by myself is not a
good idea.
Hoping a favorable response.
Regards
Ranjith
Reply
Name
eMail (not visible)
Text
Please enter the number 4539
