Hello all We have bought MINI2440 development kit and we are planning to use the same processor and Linux platform for our new device. We have been informed by Samsung that this processor will not be supported soon and it is better to not use in any new product. We also have SMDK2450 development kit and Linux on this board has lots of interface(s) issues. Any expert opinion on whether we can proceed with MINI2440 for Sw development would be highly appreciated. Regards Rajam
Support for S3c2440 processor
What kind of software development do you mean? Kernel or userland/application? For userland/application I see no reason why not starting development on your mini2440 (even if you change later on to another processor). Its (mostly) independent of the processor it runs on. I don't know the 2450 yet. But if you want to do some development in the kernel area, you should start with the new processor and forget the old one.
As Juergen stated you can develop you applications on every platform. Then just recompile for other type of CPU (2450 is ARM926) so never like 2440. marek
Thanks for the response. I meant user application in Linux. I do not want/ have time to do kernel related updates. But the basic Linux kernel is giving problems in S3C2450 based board which includes ECC errors being reported in NAND, no LCD and touch screen interface and no camera interface etc., But the kernel that came with mini2440 has all the basic interfaces up and running. Regards Rajam
So you need to update also kernel (or put some development effort to it). Otherwise switching to other platform (2450) would be impossible ;). Bad new is that also mainline kernel AFAIK doesn't have support for 2450 :(. marek
Hi Rajam, if the S3C2440 comes with all interfaces you need for your application and the S3C2450 also supports these interfaces, then you really can start with your application development on the mini2440. In the meantime the support for the S3C2450 may occur in the kernel, so you can switch later on to this new processor.
Hi As suggested we have started with the application development using MINI2440 and we will plan to later port it to S3C2450 based board. Hopefully we should be able to ride through this .... Thanks a lot for all the responses and sharing, regards Rajam Qmax Systems
