Hi, To make the file system in mini2440 more consistent, I am thinking about creating all the temporary data in SDRAM. How can I do that? For example, I wrote an application that decode a file, store it to filesystem, print it out and delete it. All the function is separate, and they are piped. So, it is a good point to move the temporary file to RAM. Another thing is when I running the mini2440 using NFS, I see some file in the /tmp folder, which is the /export/fs/tmp folder on the host computer. But I can not see those file from host computer. Is this because the /tmp folder on mini2440 already in SDRAM? Thank you very much BAO
create file on SDRAM
Run the "mount" command on your target. On mine the /tmp is a tmpfs tmpfs on /tmp type tmpfs (rw,mode=1777) And yes: This means this directory is in SDRAM from the sight of your target.
