I brought Mini2440 X35 development board, I installed wince 6.0 with Nk_N35.bin. It loads succefully, the problem is touch screen interface is flipped. I googled and check., that X35 is Sony Lcd., so, i might need X35 driver. Provide me the LCD driver for it.,
Mini2440 X35. Win CE Touch Sccreen
Hello Dhinesh, Even I am facing the same problem. Could you find the solution for your problem?? If so can you share it.
If you are using the image from DVD then, just calibrate the touch screen. it will work. If you are developing the image then go to C:\WINCE600\PLATFORM\Mini2440\SRC\INC in that options.h select the display option listed .., mine is X35 so i chosen # define X35... then build the image again and load it, then calibrate the touch screen it will work.
Hello Dhinesh, Thank you so much for the responce. Now I have a hope that, this problem will be rectified. Can I know more about calibration, how exactly to do it?? as I am using the Image which is given in the DVD. Thank you once again.
Hello everybody I have a mini2440 with x35 LCD too my problem is I load the WINCE6.0 from the thaieasyelec and install to my mini2440, it works but the backlight is always off. Before that I use WINCE5 and it works fine. How can I turn on the backlight? Thank you!
