Hi. Could anybody please explain how could I write a YAFFS image (created with the mkyaffs2image tool) to an SD card so the default Linux kernel can recognize it as a YAFFS2 partition and boot from there? Thanks.
YAFFS on SD
you cannot write directly yaffs2 to a SD card, and as it supposed to be used by NAND devices (on board memory) you should rather format SD card by standard FS like VFAT, EXT2, EXT3 etc.. Then grab .tar file with your rootfs (normally generated by openembedded besides .yaffs2 file) and untar it directly to the card. there are plenty articles about it for mini2440 http://code.google.com/p/mini2440/wiki/QEmuSDCardImage
