Hi, I am a newbie on the Mini2440 board. I am having some problems in compiling the kernel. The kernel provided at kernel.org have no support for the yaffs2 file system. How can I patch the provided kernel? I have tried to patch from two or three locations but still it can't build the kernel successfully. Thanks.
Kernel 2.6.34 patch
Why you don't use 2.6.32 or mainstream kernel but 2.6.34? Is there some particular think you need (except yafss2). IN latest kernels you could use ubifs. marek
I have builded kernel with jffs2 file system successfully. And I have
loaded it onto uboot through a tftp server.
The environment variables are as follows.
bootdelay=3
baudrate=115200
ethaddr=08:08:11:18:12:27
netmask=255.255.255.0
usbtty=cdc_acm
mtdparts=mtdparts=mini2440-nand:256k@0(u-boot),128k(env),5m(kernel),-(root)
mini2440=mini2440=0tb
bootargs_init=init=/sbin/init
root_nfs=/mnt/nfs
ifconfig=ip=dhcp
${mini2440} ${root_mmc}
${mini2440} ${root_nand}
mtdids=nand0=mini2440-nand
bootcmd=nboot.e kernel ; bootm
ipaddr=192.168.1.41
serverip=192.168.1.40
gatewayip=192.168.1.1
bootargs=root=/dev/mtdblock3 rootfstype=jffs2 console=ttySAC0,115200
partition=nand0,0
mtddevnum=0
mtddevname=u-boot
But now when I boot the kernel it gives Kernel panic. What can be the
problem?
Loading from NAND 128MiB 3,3V 8-bit, offset 0x60000
Image Name: Linux-2.6.33-mini2440-FriendlyAR
Created: 2011-03-16 1:46:37 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2056336 Bytes = 2 MB
Load Address: 30008000
Entry Point: 30008000
## Booting kernel from Legacy Image at 32000000 ...
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 2.6.33-mini2440-FriendlyARM (junaidm@localhost.localdomain)
(gcc version 4.1.2 (Fedora GP2X 4.1.2-11.fc12)) #3 Wed Mar 16 06:41:56 PKT
2011
CPU: VIVT data cache, VIVT instruction cache
Machine: Mini2440 - ARM9 development board
CPU S3C2440A (id 0x32440001)
S3C24XX Clocks, Copyright 2004 Simtec Electronics
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
Kernel command line: root=/dev/mtdblock3 rootfstype=jffs2
PID hash table entries: 256 (order: -2, 1024 bytes)
Memory: 64MB = 64MB total
Memory: 60804KB available (3608K code, 355K data, 108K init, 0K highmem)
SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Hierarchical RCU implementation.
NR_IRQS:85
irq: clearing pending status 02000000
console [ttySAC0] enabled
Mini2440: Features string mini2440=0tb
Mini2440 Buttons:
[0: ENTER ] [1: UP ] [2: POWER ]
[3: LEFT ] [4: DOWN ] [5: RIGHT ]
Mini2440 LCD type:
NONE
> 0: NL2432HC22 3.5" (240x320)
1: TD035STED4 3.5" (240x320)
2: AT056TN52 5.6" (640x480)
3: AT070TN83 7.0" (800x480)
4: VGA board (1024x768)
s3c24xx-adc s3c24xx-adc: attached adc driver
S3C2440: IRQ Support
S3C24XX DMA Driver, Copyright 2003-2006 Simtec Electronics
DMA channel 0 at c4808000, irq 33
DMA channel 1 at c4808040, irq 34
DMA channel 2 at c4808080, irq 35
DMA channel 3 at c48080c0, irq 36
bio: create slab <bio-0> at 0
SCSI subsystem initialized
s3c-i2c s3c2440-i2c: slave address 0x10
s3c-i2c s3c2440-i2c: bus frequency set to 98 KHz
s3c-i2c s3c2440-i2c: i2c-0: S3C I2C adapter
Advanced Linux Sound Architecture Driver Version 1.0.21.
cfg80211: Using static regulatory domain info
cfg80211: Regulatory domain: 00
(start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
(2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
(2457000 KHz - 2482000 KHz @ 20000 KHz), (600 mBi, 2000 mBm)
(2474000 KHz - 2494000 KHz @ 20000 KHz), (600 mBi, 2000 mBm)
(5170000 KHz - 5250000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
(5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
cfg80211: Calling CRDA to update world regulatory domain
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered tcp NFSv4.1 backchannel transport module.
JFFS2 version 2.2. (NAND) (SUMMARY)
������ 2001-2006 Red Hat, Inc.
msgmni has been set to 118
alg: No test for stdrng (krng)
io scheduler noop registered (default)
Console: switching to colour frame buffer device 30x20
s3c2440-uart.0: s3c2410_serial0 at MMIO 0x50000000 (irq = 70) is a S3C2440
s3c2440-uart.1: s3c2410_serial1 at MMIO 0x50004000 (irq = 73) is a S3C2440
s3c2440-uart.2: s3c2410_serial2 at MMIO 0x50008000 (irq = 76) is a S3C2440
loop: module loaded
at24 0-0050: 1024 byte 24c08 EEPROM (writable)
s3c24xx-nand s3c2440-nand: Tacls=3, 29ns Twrph0=7 69ns, Twrph1=3 29ns
s3c24xx-nand s3c2440-nand: NAND soft ECC
NAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung NAND 128MiB 3,3V
8-bit)
Creating 4 MTD partitions on "NAND 128MiB 3,3V 8-bit":
0x000000000000-0x000000040000 : "boot"
0x000000040000-0x000000060000 : "param"
0x000000060000-0x000000560000 : "kernel"
0x000000560000-0x000008000000 : "root"
dm9000 Ethernet Driver, V1.31
Now use the MAC address: 1C:F7:1A:3D:89:E3
eth0: dm9000e at c487a300,c487e304 IRQ 51 MAC: 1c:f7:1a:3d:89:e3 (mini2440)
usbcore: registered new interface driver rt73usb
usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: S3C24XX OHCI
usb usb1: Manufacturer: Linux 2.6.33-mini2440-FriendlyARM ohci_hcd
usb usb1: SerialNumber: s3c24xx
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver usbserial
usbserial: USB Serial Driver core
USB Serial support registered for pl2303
usbcore: registered new interface driver pl2303
pl2303: Prolific PL2303 USB to serial adaptor driver
mice: PS/2 mouse device common for all mice
s3c24xx-ts s3c2440-ts: driver attached, registering input device
input: S3C24XX TouchScreen as /devices/virtual/input/input0
S3C24XX RTC, (c) 2004,2006 Simtec Electronics
s3c2410-rtc s3c2410-rtc: rtc disabled, re-enabling
s3c2410-rtc s3c2410-rtc: rtc core: registered s3c as rtc0
i2c /dev entries driver
S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics
s3c2410-wdt s3c2410-wdt: watchdog inactive, reset disabled, irq enabled
s3c-sdi s3c2440-sdi: powered down.
s3c-sdi s3c2440-sdi: mmc0 - using pio, sw SDIO IRQ
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
No device for DAI UDA134X
No device for DAI s3c24xx-i2s
S3C24XX_UDA134X SoC Audio driver
UDA134X SoC Audio Codec
asoc: UDA134X <-> s3c24xx-i2s mapping ok
ALSA device list:
#0: S3C24XX_UDA134X (UDA134X)
TCP cubic registered
lib80211: common routines for IEEE802.11 drivers
s3c2410-rtc s3c2410-rtc: setting system clock to 2011-03-16 12:47:25 UTC
(1300279645)
Cowardly refusing to erase blocks on filesystem with no valid JFFS2 nodes
empty_blocks 979, bad_blocks 0, c->nr_blocks 981
VFS: Cannot open root device "mtdblock3" or unknown-block(31,3)
Please append a correct "root=" boot option; here are the available
partitions:
1f00 256 mtdblock0 (driver?)
1f01 128 mtdblock1 (driver?)
1f02 5120 mtdblock2 (driver?)
1f03 125568 mtdblock3 (driver?)
unknown-block(31,3)
Cowardly refusing to erase blocks on filesystem with no valid JFFS2 nodes empty_blocks 979, bad_blocks 0, c->nr_blocks 981? How did you load image to flash? Seems it's not correctly written. marek
I have loaded the uImage into ram using TFTP. nand erase kernel tftp 0x32000000 uImage nand write 0x32000000 kernel Tarjun
