Hi all. I am trying to complile the Kernel to my board Mini6410, I am using de source code including into the DVD(Mini6410A-20110112), version of kernel it's 2.6.36. With make menuconfig I checked in System type SMDK6410 and then I try to complile using make but I got this error: arch/arm/plat-samsung/built-in.o:(.data+0x1650): multiple definition of `s3c_device_ts' arch/arm/mach-s3c64xx/built-in.o:(.data+0x2d40): first defined here make: *** [vmlinux.o] Error 1 If I select Mini6410 type I can compile it but when I try to run the Kernel in the board I got a error Unsoported machine or sonthing like that. How can I solve this problem? Thanks.
Error compiling Kernel - multiple definition of `s3c_device_ts'
Hi open-nandra. I am using the source include into a ISO image downloaded from the FTP of this syte. I upload the kernel source here http://www.megaupload.com/?d=IA492G60 I am using the config_mini6410_n43 file(copy and rename to .config) then I execute make menuconfig In the Genaral Setup I define the crooss-compiler arm-none-linux-gnueabi-(full path) before I execute make When the Kernel it's ready I copy the zImage from arch/arm/boot/ to the SD. This is the error using Mini6410 System type. ------------------------------------------------------------------------- Running OS 'LINUX' Loading kernel... Load kernel succeed Start Linux kernel... Uncompressing Linux... done, booting the kernel. Error: unrecognized/unsupported machine ID (r1 = 0x0000065a ). Available machine support: ID (hex)\0x09NAME 000009d8\0x09MINI6410 Please check your kernel config and/or bootloader. ------------------------------------------------------------------------- I have compiled a previous version of the Kernel after and I have not problems but I want to test 2.6.36 version. Thanks. Sorry for bad English.
You need to update your bootloader. Bootloader pass to kernel wrong machine ID (for SDK_6410) not for mini6410. marek
I update Superboot(Include into de ISO Image superboot-20101223.bin) and now boot using the kernel 2.6.36. I continue with the same error trying to load the root file system from the SD. Thanks open-nandra :)
Tuxerito, have you solved the problem with multiple definition of `s3c_device_ts'? I have the same problem - read6410, tiny, mini, etc works fine, but samsung SMKD6410 gives this error.
No, I have no solved that problem. My problem was that I was trying to compile a newer version of the kernel and I checked SDK_6410 target and the bootloader that I was using does not boot the kernel becouse it was configured to use a Mini6410. In previous version of the kernel include into de DVD, the target machine was SDK_6410 and Superboot was compile to that target(SDK_6410), so in the new version the default target is Mini6410 and the new Superboot works with Mini6410, then I was using a new version of kernel and old version of Superboot, that was my problem. Solution for my problem was update the old Superboot to the new version. The error "Multiple definition of `s3c_device_ts'" was when I was using SDK_6410 type, but before a change the target to Mini6410 and that error does not appears. Sorry for bad English.
