Hello, When a VCP device is connect, what will be the new com port number on MINI2440? The VCP driver is installed successfully but not able to figure out the new com port number.
VCP (Virtual COM Port) Name?
I also use a FTDI multiserial, but if I connect to a USB hub I errors. For example, serial ports are disappearing and I can not open them ... This happens on both WinCE 5 to 6
Hello: also I am trying to use ftdi_ser.dll for ARM. and it does not appear by any place a new port! . It tries with all the ports. In CE6.0 this qualified from the port com1 to the port com9. when attempt to use the port com10 says to me that it is not a name qualified like com port. I am using compact framework with visual C# studio 2008 somebody already had some experience with this?
I got it working, -Download the driver from FTDI; http://www.ftdichip.com/Drivers/VCP/WinCE/CE60/ARMv4VCPDriver.zip -or for ce50 http://www.ftdichip.com/Drivers/VCP/WinCE/CE4252/ARMv4VCPDriver.zip -Copy Ftdi_ser.dll and ftdiport.inf to the \Windows directory of you Friendlyarm -Plugin your ftdi device and on the screen comes an messagebox "Unindentified USB device" , type now in this box ftdi_ser and it should work. -For me the port occurs with the name; $device\COM10. In Vb i'm using the following to get all the port names in an array, i believe the syntax is almost the same in C#. Dim nameArray() As String nameArray = System.IO.Ports.SerialPort.GetPortNames Have fun.
hello
thank you very much!
it was of much aid! the error that was committing, was that only it placed
COM10, time to put $divece\COM10,
serialPort1.PortName = $divece\COM10
is why it did not detect the door to me.
for see them,
string[] ports = SerialPort.GetPortNames();
foreach (string port in ports)
textBox1.Text = ports[4] ;
andres thanks
has anyone tried to connect the multiserial to a USB hub? WinCE fails to correctly recognize the COM ports
I don't know exact what you mean with "multiserial" , but the FT2232C works fine here with ce60 The FT2232C is an dual serial and gives me $device\COM10, $device\COM11
I use the FT4232H chip as multiserial with 4 serial ports. I'm using both the driver D2XX (http://www.ftdichip.com/Drivers/D2XX.htm) that the VCP (http://www.ftdichip.com/Drivers/VCP.htm) without problems. My problem is that if I put in the middle a USB hub (mini2440 only has a USB port!), I can not access the ports correctly. I am clear?
hi Edje11 I put into my image nk.bin with platform builder 2 files: ftdi_ser.dll and ftdiport.inf and typed in textbox "ftdi_ser.dll" (the window doen't disappear and I have to close it), but every time I reboot with the device connected, this not detected. I have to disconnect and reconnect ... Why?
every usb device connected at the WinceCE startup is not detected.I have to disconnect and reconnect it... Is it possibile that my image made with platform builder is wrong?
