Hi, I downloaded kernel 2.6.32.2 from friendlyarm.net downloads and compiled it for mini2440 using buildroot. Both uImage and rootfs.jffs2 are working, but my backlight is turned off. I can see the pinguim image and login but the backlight is always off. I'm using u-boot and I tried to change "mini2440" parameter, using like, 0tb, 1tb, 2tb and this does not make difference. Same results for anything that i enter in "mini2440" parameter. Some one know how turn on the backlight in this kernel? This "mini2440" parameter is working in kernel 2.6.32.2? Thanks.
Backlight off - kernel 2.6.32.2
Hi, I solved the problem. I was making the kernel 2.6.32.2 with default config instead of t35_mini2440. To compile with buildroot I put the t35_mini2440 inside archs/arm/configs directory and select to use defconfig with the right name. Name like "t35_defconfig" Now, backlight is ok. I tried the udev option and now everything is inside /dev/ backlight, leds and etc. Best Regards.
