Hi I am a newbie to Embedded Linux and Mini2440. I am trying to follow the steps in http://wiki.linuxmce.org/index.php/Mini2440 to get my mini2440 up & running. Under the section "Compiling uboot", I get error while running "make mini2440_config" from uboot/mini2440 directory. "" make: arm-none-linux-gnueabi-gcc: Command not found Configuring for mini2440 board... "" Can someone point me the cause of the error. I am working on an Ubuntu system. Do I need to setup a cross-compiler? If yes, how? The wiki page does not mention anything about it. Thanks a lot.
Compiling uboot
1. Download the toolchain: http://www.friendlyarm.net/dl.php?file=arm-linux-gcc-4.4.3.tgz 2. And then unpack it to your filesystem: "tar xvf arm-linux-gcc-4.4.3.tgz -C /" 3. Then set the path to your toolchain in your .bashrc gedit /home/<your_username>/.bashrc add the following line at the end: export PATH=$PATH:/usr/local/arm/4.4.3/bin You're welcome.... ;-)
Hi all, For now I use an u-boot-256M.bin pre-compiled, but I want to configure and compile my own u-boot. I'm using buildroot2 toolchain, but I can't compile it when I choose U-boot to mini2440: $make make[1]: Entering directory 'buildroot/output/build/u-boot-2010.12' make: *** No rule to make 'mini2440_config'. Stop. How should I configure a mini2440_config file? Sorry my english isnt very good. Thanks.
Are you using the mainline u-boot? I did a quick look into it: It does not has mini2440 support. You need a special branch with mini2440 included. Maybe one from here http://repo.or.cz/w/u-boot-openmoko/mini2440.git
