Hello, I am working on s3c6410 with WinCE OS, I ported the SD card driver and using channel "0" for sd card detection (there are 2 channels, "1" is used for wifi). The driver detects the 2GB microSD card as "SD card spec version : 2.00" clock rate 25MHz. when OS boots up I am able to see the storage card folder and the contents of the card but i am not able to copy anything from/to the card. If i try to copy into the card it gives me error that there is no space If i try to copy from the card it gives me error code 31 and exits. can anyone please tell me what might be the problem !! Thanks a lot Manoj
sd card detection issue in wince
Hi Edje11, I tried with a LG card i have and also tried with 1GB and 2GB capacity the result is same, i can see the contents but i cannot copy from/to the card any other solution please
