Dear All, I am running debian on mini2440, rootfs on SD card. but I am unable to log in over serial console. I have tried many user name password combination but did not work. I also have tried T0:123:respawn:/sbin/getty 115200 ttySAC0 it should include T0:2345:respawn:/sbin/getty -L s3c2410_serial0 115200 vt100 Also the /etc/securetty should list s3c2410_serial0 device instead of ttySAC0 as it was given on http://code.google.com/p/mini2440/wiki/Emdebian but it does not show console. I am using rootfs from thai-embedded Thanks in advance....
Login failed in Emdebian!
Good I've a question, How do you do if u want to execute a command u need root privileges ? Because I would like to copy the rootfs to nand but I need root privileges...
just change put init=/bin/sh into your boot parameters and you will get to a shell after booting. the type "passwd" and enter your new root password. that's it. reset init=/... to whatever it has been before. Daniel
Dear Daniel, I could log in the debian. But now I am having problem with touch screen. i am able to sense the touch input, and also pointer moves, but its not like mouse. I mean if i click on debian button it displays the options until i keep stylus on touchpad. as soon as i remove stylus the options disappear. I have checked with thnx
